Question about Frigidaire FSG748GF Dryer
The drum when turning is wobbling.There are no support rollers on this dryer.
    Problem Solver:
  • 16 Answers
I just looked at Searspartsdirect.com there are two possibilites for this dryer the cheaper one is bearing support part Number 131825900 that could be worn.  They also offer what looks to be a complete kit that replaces the previous part and also the part on the center of the rear drum.
This is called Bearking 5303281153 it appears to be a whole kit to include the lube for the ball portion of the plate that goes into the socket.  Quite possibly the bearing support has just worn out over time from the lubrication drying out.  The easiest way to work on it only once is to buy the bearing kit and replace it the lube keeps the plastic (well fancy nylon impregnated plastic) from wearing out prematurely.
Hope this helps
Posted on Feb 05, 2010
My dryer WGD96HEAW1 makes vibrating and grinding noise after heats up, not in the beginning when turned on.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Feb 28, 2016 | Dryers
I have a whirlpool gas dryer. One of the drum rollers keep getting shredded and breaking only after a couple of hours of use. I have now replaced both drum rollers 5 times in the last 6 weeks.
Did you lube the bearing surfaces of the new rollers with a good lube? Is the shaft surface for the bearing smooth? Do the new rollers wobble on the shaft (very bad)? Do your have the drum on straight and is it riding on the felt surface in front ok? Do the rollers turn easily after you install them or are they jammed up for some reason? What does the surface on the drum where the rollers ride look like? Does the idler pulley for the belt hold the belt steady in the correct place on the drum or does it wobble around? I have serviced these rollers on many occasions and they last a long time. The felt in front should be both in front of the drum and reach across the outer front edge of the drum. Sometimes it get all bunched up at one spot in front of the drum without wrapping around the outside too. I put the bottom in first and then use a J shaped piece of bent tin to guide it in on top where I can't see it.
Dec 12, 2015 | Whirlpool Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
I have a maytag neptune dryer and the drum is loose how do i tighten it?
Why do you say that the drum is loose? Are you able to wobble it by hand? If so, that is evidence of a bad roller that the drum sits on.
If the drum doesn't turn as fast as it did, that is probably a loose belt, which would indicate that the belt tensioner is not working or belt has jumped the tensioner.
Jun 13, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
When i turn the dryer on i hear a noise but seems
IF IT IS AN OLDER MODEL, THERE ARE IDLE ROLLERS THAT SUPPORT THE DRUM AS IT RUNS AND THE CENTER GETS WORN WITH THE ROLLERS WOBBLING AS THE DRUM TURNS. OR IF DRUM DOESN'T TURN THE BELT MAY BE BROKEN.
Mar 10, 2010 | Kenmore Dryers
I have an Amana ALE643RBW drum needs manual assistance to tumble
If you remove the back panel you will be able see the drum rollers. There's a good chance they may be worn out. As long as you are replacing the rollers I would suggest replacing the belt at the same time.
Typically when the rollers wear out, the drum drops ever so slightly and the drum wears on the front and rear drum to cabinet seals.The added drag can cause a slow drum and squealing noises.
Good luck, let me know if there is anything further you need.
Regards,
Aug 18, 2009 | Amana ALE643RB Electric Dryer
Squeaks alot when it is drying clothes, my husband replaced the belt, and front felt. what could it be?
Replace the tensioner roller assembly that tensions the belt. also, check the rear drum rollers that the drum rests on for free spinning but no wobble or noises, If loose or wobbly, replace them too.
Aug 04, 2009 | GE Profile DPSB620GCWW Gas Dryer
Loud thumping sound
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
