Question about Microsoft Xbox Console
My xbox has a red light flashing were player 4 light is whats wrong?
  • Microsoft Master
  • 2,404 Answers
Your board has a bad eeprom, here is a link from LLAMA on how to fix the issue:
http://www.llamma.com/xbox/Repairs/eeprom_fix.htm
Posted on Feb 04, 2010
When i turn my xbox 360 on the green light stays on for 30 seconds and then turns red and wont play what would be wrong
While on the RED light. Press and hold the "SYNC" button (don't let go if it during any of the stages). Now press and release the "EJECT button. Note the amount of flashing lights. Do this three more times (still holding the sync button) each time noting the amount of lights that flash. This will give you a total of 4 numbers. Go here to see what the issues is. https://xbox-experts.com/
Oct 19, 2014 | Microsoft Xbox 360 Console
My xbox stop working i have not even had it for a year and a half and i want to know whats going on?
hello hi there i just recieved your comment on your xbox??whats wrong with it exactly?has it got 3 red lights showing?if so please say,if it has 4 red lights just plug the cable in better or its a error code being shown whats the numbers comming up the xbox 360 is more intelligent than the ps3 all you have to do to find what the correct error code is- press at the same time the eject button and at the same time the sync button and it will flash the lights if the whole 4 parts of the lights flash at once that means code 0 if you press it 4 times like that in total it will give you the 4 digit error code which is how you define whats wrong with your xbox a lot more precisely any more questions just ask please give positive feedback im trying to sort this problem out personly you with untill its gone so please at least give me positive feedback and i hope we can fix your problem together.thank you p.s. go to my website if it helps you xbox360repairspro.webs.com
Jun 04, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
My xbox redlined and told me to contact manufacturer
you have one red light of death it will have to be refurbished
Nov 12, 2009 | Microsoft Xbox® 360 Core System Console
3 then 4 red flashing lights
the lights let you know that your x box is not working correctly it is defective and you could also call it lights of destrution... what you need to do is call take the xbox back and inform them of this problem and they should have it fixed for you
Jul 26, 2008 | Microsoft Xbox 360 Console
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
Three flashing red lights
this means your system is not properly conected also on yor video conponent check to see if its set on tv or hd mess around with it
Jan 03, 2008 | Microsoft Xbox 360 Console
4 red lights
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
