Question about Panasonic Lumix DMC-FX3 Digital Camera
When I turned on this camera, the battery showed me that it is not enough to take a picture and suddenly cam went off and the lens stayed open.after that i started to recharge the battery but somehow aftersometime it seems that it is not charging.so what should i do?could you pls suggest a solution.
  • pelincanlitu Feb 05, 2010
    I am using the charger. As far as I know it is not possible to charge in the camera itself.The lens doesnt align.it stayed as it is turned on.
    thanks for your support,
    pell
  • pelincanlitu Feb 08, 2010
    Thank you for your great support.
    I will try them.
    Brigadier General:
  • 11,967 Answers
Are you charging the battery in the charger or in the camera?
Posted on Feb 04, 2010
  • Ty Price Feb 05, 2010
    If It's a lens problem, try these:
    Fixing a Lens Error on a Digital Camera
    This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
    The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
    A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
    Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
    The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
The lens does not stay open long enough to pose picture. It closes.
These camera's will do that when the battery is very low sometimes.
I'm not sure that is your problem due to lack of more details, but it is a possibility.
Mar 08, 2015 | Nikon Coolpix S3300
Flip cam won't connect to computer
I think this time your battery went flat. Not sure you can replace the battery yourself, but only with enough power, the camera will act as a external memory, so you can see and download the pictures.
Feb 19, 2014 | Pure Digital Flip Mino Digital Camera
Camera is stuck in open position
Pull the battery out and put back in then power on the camera should stick out then when you turn it off should go back in.
Aug 28, 2012 | Olympus Cameras
Z650 won't stay on
Check and or replace the small button battery on the bottom of the cam. You can use a quarter to open the cap. remember which side of the battery is facing up when you open it, VERY important.
Aug 13, 2009 | Kodak EasyShare Z650 Digital Camera
Can't take pictures
If the lens is buzzing and followed by an "E18" or "lens error" message then the lens will need to be replaced. If no message appears you may just have flat batteries or even a single bad battery can cause this. Try getting some good quality disposable batteries specifically for digital cameras. If all is well with the new ones, invest in a new set of rechargeables.
Mar 24, 2009 | Canon PowerShot A95 Digital Camera
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Dec 05, 2008 | Canon Digital Rebel / EOS-300D Digital...
Lens error
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Casio Exilim EX-Z750 Digital Camera
My lens is stuck open
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Try
Apr 20, 2008 | Kodak EasyShare V1003 Digital Camera
Won't turn on and lens is out.
Sounds like you might have gotten some pocket lint in the lens barrel. The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 15, 2007 | Nikon COOLPIX L2 Digital Camera
Panasonic Lumix  DMC-FX3 Digital Camera Logo
59 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
