Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler CH20S losing power, blowing black smoke and oil
I have a 2004/05 ch20S v twin Kohler horizontal engine that powers a Timberking sawmill with 300+ hours. Operates at 8,000 ft elevation. Started having problems with Black smoke/carboning up plugs etc after first 100 hrs, Got so bad wouldnt start. Took to Kohler repair shop, diagnosed as having cracked carburator. Had new carb, high alt. jets, and top mounted deicing/heater kit installed. After 30 hours engine starts and idles fine but when at full throttle and cutting engine will lose power, blow thick black smoke acts as if it will stall for 5-10 seconds will then return to normal for 5 seconds and repeat the above. This occurs at above 40 or below 40 degrees without/with deicng kit on. small amounts of oil are lblowing/eaking from left cylinder into muffler. I only use fresh exxon premium gas with 2 year stabil added.
  • 677 Answers
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Posted on Feb 04, 2010
How do I check for a blown head gasket
Dwayne, the third link talks about the signs and test for leaking head gasket. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
blown head gasket on kohler command pro 25 horsepower
How to replace head gasket on Kohler command
Legacy Kohler engine leaky head gasket repair
May 01, 2016 | Kohler Command V-Twin Horizontal Engine...
How much torque does my kohler k662 spec # 3966c produce at the crank?
Kohler Small Engine Connecting Rod Torques
outdoorpowerinfo.com/engine_specs/kohler_rod_torques.asp
Engine Connecting Rod Torques for Kohler small engines used on a variety of outdoor power equipment applications. ... Series, Engine Model, Engine Type, Rod Torque .....K-SERIES, K662, Air Cooled Horizontal Crankshaft Twin, 35 ft-lb.
Sep 24, 2015 | Cars & Trucks
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
now the kohler v-twin does have a bit of a problem with camshafts in this size range , your gonna need to remove valve cover on head side that you suspect is bad , verify that valves move in order (one at a time) as you turn over by hand with spark plugs removed (both sides)
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
CH670-0011 22hp in cub cadet 115 Hours smoking replaced head gasket but observed that ring job was needed Is this a normal problem with the Kohler V twins?
no it is not common long period's of sitting the lube will wash off the rings and a squirt of oil will help prolong life of the rings that's if the engine was sitting for a wile hope this helps
Aug 23, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Motor runs erratically
Try cleaning the air filter and the fuel filter. Sawmills are dusty places and timber dust can clog-up air filters. Air filters in chainsaws are cleaned hourly for max efficiency.
Oct 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Check engine light came on while driving at 8,000 feet elevation
is this car high allitude certified? if not then that is most likely the cause of the light.
Jul 07, 2009 | 1999 Hyundai Accent
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
1,635 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
