Question about Dimplex CKHA20D31 Electric Heater
Dimplex heater model rkha20d31w schmatic to wire for different wattages
Can i change wattage on my dimplex fire place model dfb 8842
This model does have 2 elements and it will likely cut the wattage in half if you disconnect one. Not sure how hard it is to get to the heater assembly, but there are terminals on the right side that probably have spade disconnects. If so, remove one marked D or E, and tuck it away and see if it puts out less heat.
Dec 19, 2015 | Dimplex Heating & Cooling
How to get to and change the bulb on my Dimplex heater. Serial # 18406D2F 297
Remove the bottom panel in the back. Make sure 60 watts or less. the lesser wattage gives you a ember effect.
Jan 30, 2015 | Dimplex Heating & Cooling
Bulb replacement
Dimplex uses common bulb types. Either incandescent or halogen. Consult your owner's manual for bulb type and wattage, then visit your local hardware or convenience store. It should be easy to find. If you lost your manual, simply remove the old bulb and bring with you to the store.
Feb 04, 2013 | Dimplex CS3311 Compact Heater
Cord on electric heater gets very hot
I've seen a couple different models of portable electric space heaters do this. These things draw A LOT of power - anywhere from 1000 to 1800 watts! Some models were built with an undersized cord for the job. It's simply too small, and overheats as a result. This is an unsafe condition. Stop using this heater, and repace the cord with the correct gauge wire.
Oct 16, 2011 | Dimplex Compact Electric Flame Stove...
Can I change my Dimplex SHB20 from coal to logs
Probably not. The flame configuration is different from one model to another, as is the coal and log holder. But, if you'd like to confirm this Contact Dimplex USA Customer Support 800-668-6663 or their technical Specialist 888-346-7539.
Hope this helped you. Please let me know. Thanks.
May 18, 2011 | Dimplex Compact Electric Flame Stove...
I need a new flame generator drive motor / spinner for my Dimplex Model No. 6901050100
what kind of on off switch do i need ,has one black wire and one white wire?
Oct 14, 2010 | Dimplex DS5598 Mid-Size Heater
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Please help me to get the manual. dimplex thermostat, or i need help to stall my thremostat
Dimplex products are typically sold at most Home Depot and professional electrical supply houses. However, they rarely will have all the literature for those products in their stores.
Dimplex once provided an online list for all their heaters and thermostats, but no longer have the product manuals available on their website for customer download. They make both 120V-AC and 240V-AC versions and several different models, so I can't safely provide you with the wiring connections, since each installation is different and depends on the type of thermostat and heater(s) being utilized.
So now that I've given you the bad news, let's move onto the good news!Dimplex now uses an online request form for customers to get manual and literature on all their products. They'll send you the manual for your Dimplex product free, once you submint the request.
Here's the link to the request form for you to fill out and submit, just have your model number handy and you should be all set.
http://www1.dimplex.com/customersupport.aspx
Hope you find this Very Helpful and best regards!
Sep 18, 2009 | Dimplex Heating & Cooling
Dimplex CKHA20D31 Electric Heater Logo
179 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
