Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
Can't figure out how to get the bulb out of the
Help!! I'm replacing a bulb in my BIG screen TV (RU 52SZ 61 B) and can't seem to get the old bulb out!! It should be easier than this I would think but don't want to do anything that will make the problem worse!
I've taken all the connecting wires off and still can't remove it. There's 3 screws by the bulb, do I unscrew those?? I tried simply sliding the black casing out, but it won't budge!! Any assistance would be terrific as I am under here now trying to figure it out. I don't want to force anything to make it worse so what now? Thank you very much.
Austin
  • LG Master
  • 1,793 Answers
First requirement is wearing a safety goggle.
place a crt tube on a higher point a thick stack of books or a folded blanket and push down the .cabinet .
Make sure that the display tube is stable and flat and the tube foot is up is the best way to disassemble the cabinet.
4 vertices are normally only 4 nuts on the older crt televisions a degauss cable and earth cable with a spring much more is not to find maybe there is somewhere some glue used , never have had problems , in my own tv repairs 20 years ago with that kind of replacements.
Success
Posted on Apr 21, 2017
techman
  • 3130 Answers
SOURCE: LG RU-27FB30
what do you mean "knocked" Yes sir it sure does sound like the power supply specificly the stand by supply? Only real way to tell if you know anything about troubleshooting solid state electronics is to get a schematic and start at the beginni9ng of the supply and work your way over to the sweep supplys. On alot of sets the horizontal has to be good for the ,main switching supply to start up but in this case if it dosent click or make any sound I supect the main supply. Good luck
Posted on May 26, 2006
eagle338
  • 4889 Answers
SOURCE: fiesta 2001 driver's wing mirror
It's basically a case of taking the door panel off! (This is for driver and passenger sides). Firstly remove the screw holding on the black plastic cover where the mirror adjustment control is and remove the black plastic surround. There is also a circular piece of plastc behind the mirror adjuster, make sure you remove this (turn anticlockwise) otherwise you won't get the mirror out later on! Next remove the screw from the door bin, inside the recess in the arm rest part of the door panel and from behind the door handle surround. Carefully slide the door handle surround off (first towards the front of the car and then towards you). Once the surround is off carefully unclip the speaker wire from the back.
Once you've done all this you are ready to go - the door panel itself is held on by plastic poppers, there are around 2 either side and 3 at the bottom. Carefully unclip all of these so that the panel is loose. Then slide the panel up (there is a plastic fitting at the top of the panel which sits in the gap where the window is). The panel will now come away - be careful not to rip any of the thin foam like lining of the panel and also of the wires going to the speaker.
There are 2 more screws which hold the wing mirror on - unscrew both of these and the wing mirror will now come off. Make sure you keep the sponge padding as you will need this to help you hold the new mirror controls in place. Then its quite simply a case of fixing the mirror on with 2 screws and refitting everything in reverse of taking it off.
Posted on Oct 23, 2007
SOURCE: TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Posted on Jan 11, 2008
  • 489 Answers
SOURCE: replacing hall sensor
The hall sensor is located in the back of the washer.  You need to get through the back panel to get to the hall sensor.
Posted on Jul 23, 2008
SOURCE: LG Shine KE970 Screen Replacement Instructions
http://cnn.cn/shop/video_info.php?videos_id=20
Posted on Jul 31, 2008
Screen is losinjg brightness. Seems to be fading and alot less bright. I tghink it is the bulb.
since this is a projection I would say that most likely the bulb is your problem. I also have a projection tv and like every 3-4 years i have to replace the bulb..
Jul 02, 2011 | RCA D61W136D 61 in. TV/DVD Combo
How to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
1993 52 inch rear projection rca tv
i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Nov 03, 2007 | LG RU-52SZ30 52" Rear Projection...
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
LG Rear pro RT-52SZ30RB
When did you replace the lamp last time?
When was TV purchased?
Please reply to lampsale@tpg.com.au
Oct 04, 2007 | LG RU-52SZ30 52" Rear Projection...
Do i need a new lamp
Sep 23, 2007 | LG RU-52SZ30 52" Rear Projection...
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Lg-ru44sz63d
I have been having the same issue with mine. After reading this solution, I tried just this... I pulled out the bulb holder (with bulb) and shook it. Once I put it back in it worked. My LG is not quite 3 years old but I first had this issue about 7 months in with increased frequency of the problem.
Feb 21, 2007 | LG RU-44SZ61 44" Rear Projection...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Computer Repairing
Computer Repairing
