Question about Tomtom GO 910
TomTom go 510
Battery won't charge even when green light is on.
  • Anonymous Nov 14, 2008
    wont charge in the car.
  • Isharryf Dec 15, 2008
    At home it charges fine, but in the car, the green light is on, but does not charge. I found out that if you ben/enforced the tt910 on the windshielddock a little it does switch to charging. But if you let go, it will easily stop charging. I looks like something is wrong with the connecting between the TT910 and the windshielddock.
I need instructions on changing TomTom GO910 battery please
Posted on Jan 31, 2009
  • 178 Answers
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Posted on Feb 20, 2008
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
My go 510 is about 1 year old and it was working
try resetbutton, go tomtom.com, sel support, search reset, sel softreset sel device, do as told. goodluck
Feb 13, 2010 | Tomtom GO 510 GPS Receiver
My TomTom 510 will not hold charge and now cannot be switched on
If you are not bothered about using it on battery your tt should work if you have it hooked up to a external power supply such as the car charger or home charger. If it doesn't work using either of the power supplies then your problem is deeper than just needing a new battery. Check the pins on the bottom of your tt to see if they are bent, or out of place. The most common problem for them is the negative pin on the far left with the lcd screen facing away from you gets bent or is not making contact even though the green light is on.
Hope this helps
Mar 06, 2009 | Tomtom XL 330 Car GPS Receiver
I purchased tom tom go510 14months ago, but it will not charge in house or car charger, what shall i do, this cost me over 269.00, i am not very happy its only lasted just over 12 months
I would call tomtom and see if they can send you a new battery sounds like it might be bad,is the green light showing that's it charging?if so and the battery isn't holding a charge I would call them and say that it went bad about 2 months ago.Good luck
Jul 28, 2008 | Tomtom GO 510 GPS Receiver
Tomtom 510 battery not holding charge
how do i get the battery out of a t/t 510
Apr 16, 2008 | GPS
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Tom tom go 510
There is a reset button (hole) underneath by the plug-in bar. It is real small, you'll need a small paper clip straighten out
Nov 05, 2007 | Tomtom GO 510 GPS Receiver
Is there sonething wrong with my tomtom go 510?
Usually resetting the unit (pressing the reset button) is supposed to fix this
Oct 22, 2007 | Tomtom GO 510 GPS Receiver
Will not charge
I have a similar problem and I think I solved it (orr found a way to work around it). It looks like the contacts are not connecting firmly so even though the green light may be on, the charging conneciton is not made. With the tomtom on your home dock from the front page on your tomtom, touch near the lower right of the screen on the satellite strength indicator, this should bring up a screen where it shows (among other things) your batter status at the top right. If it is charging, the word charging will be under the battery strength indicator. Just play with it until you get the word "charging" to appear under the picture of the battery.then HANDS OFF until it is charged. I doubt this will be successful with the car charger since the movement of the car will likely jar the connection loose. Good luck.
Oct 03, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 910 Logo
159 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
