Question about New World G70m Gas Double Oven
Mad gas flame at back of New World G70M
I have a New World G70M gas double oven and the flame seems to go wild in the back when i first turn it on then settles down after 10 minutes or so. Also i think the fan may have gone as it is now almost silent when on istead of hearing the fan. Is this repairable or do i need to look at buying another oven? Also, the grill flame has gone mad too - its melting the knobs on the top! Any suggestions?
  • New World Master
  • 3,309 Answers
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Posted on Feb 10, 2010
Oven and grill do not ignite appears to be no gas coming through either
check with multi meter ur oven safety gas valve and more than likely ur igniter switch? although the oven safety gas valve dont commonly go out it may somehow have shut off the gas as it has an on/off button usually red in color that can be tripped? check to see if its in off position
Mar 06, 2015 | New World G70m Gas Double Oven
Why has my oven and grill stopped working?
manufactor have recalls check the website to see if it includes your item. electronic controls due go bad
May 26, 2014 | New World G70m Gas Double Oven
The power keeps going off to the clock and the oven turns itself off
That is an ongoing problem with that model oven. It is the circuit board that is to blame. If the unit is still under warranty, call New World for the repair. If it's not, you will need to replace the board yourself.
Oct 17, 2011 | New World G70m Gas Double Oven
Ignition not working although there is power to the cooker (oven fan working)
we turned it off at the plug left it for a 5 minutes it then worked again
Jul 27, 2011 | New World G70m Gas Double Oven
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Oven doesnt work
you have a short most likely try to unplug for about two mins to let reset
Jun 21, 2009 | New World G70m Gas Double Oven
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
What type of gas?
Only if you fit the correct jets to the burners.They usually come with the oven
Mar 02, 2009 | New World G70m Gas Double Oven
New World G70m Gas Double Oven switches it self off and then when cooler switches it self back on and also clock resets at zero. Any ideas please.
Was sorted out with insurance from New World and it turned out to be a circuit board and all knobs replaced. You can get circuit board on ebay for about £38.00 plus postage if you are capable of fixing it yourself.
Jul 08, 2008 | New World G70m Gas Double Oven
New World G70m Gas Double Oven Logo
300 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
