I have Hatichi 60ux54b,I need a projection bulb(or what ever its called) the tv has 3 lenes. I called a local shop they said the part was no longer sold,any advice?
  • 111 Answers
Its called a crt cathoid ray tube you can get them rebuilt check on the internet i know there is a place in fla that rebuilds them good luck
Posted on Feb 05, 2010
Where can i find a manual for a hatachi 60ux54b tv
you shouls be able to getboth the user manual and the service manual from www.tvrepairworld.com
Nov 04, 2012 | Hitachi Televison & Video
We ahve an Akai Projection TV PN# PT4298HDX/SMS TV turns on but no picture
Sounds like your bulb went out, I would call the manufacture or a local TV repair shop to find the part.
Akai Corporate: 323-281-0782
Aug 27, 2011 | Akai Televison & Video
We cleaned the lenes and put new bulb in ,put the tv back together and the picture to colors like voilet color and a bright yellow took it apart 3 times..dont know what else is wrong
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 06, 2011 | Philips 55PL9524 55" Rear Projection...
I have a hitachi 55vs69 projection television. Lately, it has been shutting down every 15 minutes or so. The screen turns dark but you can still hear video until about a couple minutes later the led light...
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
  1. Lightning and other 120 vac power bumps.
  2. Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
  3. Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
  4. Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
  5. Poor quality or damaged bulb installed as replacement.
  6. Bulb damaged during replacement
  7. Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 08, 2010 | Hitachi 55VS69 55" Projection HDTV
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
Do I need to ever clean the bulbs and mirror?
Only if your picture looks hazy or foggy and not clear.
If you do not know what you are doing or haven't done it before call your local tv repair shop.
Jan 20, 2010 | RCA HD52W59 HDTV Projection Television
The bulb in the bottom front of my rca d52w25 tv is broke. i was wondering where i could find one and how hard it is to change
You can replace the bulb itself. They are tricky to do. I recommend to have a local tv repair shop to do it. If you tighten too much you can damage the replacement bulb. Buy the way a new bulb will run you about $125 or so. It is not a bad fix, compare to buy a new tv set.
I had to replace mine about a year and what we decided to do is to use a small 20" television to watch our reunions or if there is nothing on to save our lamp. Lamp are usually good for about 3 years or 80,000 hours.
Nov 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen is cracked need to be replaced
Your set has 3 screens:
FA812 SuperShield is no longer available
23837472 Lenticular lens is no longer available
23837450 Fresnal lens is also not available.
Check with some of your local TV shops. You may find a non-working TV with good screens for sale.
Good luck
Aug 10, 2009 | Toshiba TP50G50 50" Rear Projection...
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
HITACHI ULTRAVISION PROBLEM
Hi, That`s an easy one, you have a bunch of broken solder joints on the sweep board, if you are proficient at soldering you can fix this yourself, if you are NOT then call a tech out, this is a cheap, quick repair, get it done and start enjoying your set again, hope this helps, Happy Holidays.
Nov 30, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
