Question about Toshiba REGZA 47HL167 TV
47 inch Toshiba LCD REGZA TV - screen has what looks like water stain or "woodgrain-like" shadows/artifacts. They go sort of vertical but are not straight, (look like wood grain shadows). Not real obvious with complex scenes, but with solid colors it is very visible. All inputs show it, (game console, antenna, etc), and it's there all the time when the tv is on. We switched to HDMI (from component) and still have the problem. This tv is only 2 years old, and it started doing it about 6 months ago, and seems to be getting worse.
  • daniellee777 Mar 17, 2010
    Thanks for the help, but it doesn't appear to be a tuner board issue, as it happens on all inputs, and even when there is no input to the t.v.
    If I could send you a picture it might help. Is that possible?
    Thanks,
    Dan
  • Toshiba Master
  • 8,457 Answers
The only way might solved this problem,to replaced the Tuner Signal board.If the board is replaced have same problem,then ur tv have some kind of dead pixels burns in.Tries Shopjimmy.com,Ebay.com for the board part.
Posted on Feb 04, 2010
Toshiba 47 inch lcd just developed a yellow smudge to one side of screen
does it take new bulbs? whenever i have this problem with my projectors it needs a new bulb, hope that helps
Aug 25, 2012 | Toshiba REGZA 46RV530U LCD TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
My 52" Toshiba Regza has a six inch vertical line just left of center that changes color as the picture changes. Some times it stays with the same pattern for quite a while. It goes away when I turn it off...
you must either change the t- con board, or the left board strip. it is dangerous because mines caught on fire. but most like since that strip is connected to the lcd screen u will have to replace the whole entire screen.
Aug 09, 2010 | Toshiba REGZA 52RV530U LCD TV
No backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
May 24, 2010 | Toshiba REGZA 47HL167 TV
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
We just pruchased a toshiba regza..we noticed a
Well for the $$ I expected ya paid for it.... well yes. The thing ya see is a "Stuck Pixel" ... really shouldn't be acceptable..
Jan 27, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Exact same problem on 47" Regza: multicolored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 23, 2017 | Toshiba REGZA 47HL167 TV
Toshiba 47WL T66
Correct, its problem of LCD Panel and will be replaced.
No alternate solution for vertical or horizontal lines in LCD Panels.
Nov 10, 2008 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
Toshiba REGZA 47HL167 TV Logo
743 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
