Question about Daewoo DV-6T955B DVD Player/VCR
Parental block password
What's the parental blocking code on a Daewoo DV-6T955B? I'm being asked for a password and I don't have the original manual to find out what that is.
  • 1 more comment
  • ktbyrd Feb 23, 2008
    i tried 0000, but it didnt work, is there a way to reset the player??? what else can i do?
  • Anonymous Mar 07, 2008
    try 3308
  • Anonymous Mar 30, 2008
    Yes, the 3308 code removed the control input menu but now the DVD itself will not play.
I'm a CSR for Netflix.com and sometimes people call to ask us for help with our DVDs, even if the problem is really with the player. I actually got two calls about this problem today, and typing 3308, hitting stop, then play, worked! It's nice when you don't have to refer customers to the manufacturer! =)
Posted on Jun 01, 2008
  • 3 Answers
Another code that you can try that resolved my issue with parental blocks was 2211.
Posted on May 16, 2008
  • 3 Answers
If you are using a daewoo and trying to watch across the univers, enter 3308 at for the code press enter, then stop then play
Posted on Apr 20, 2008
  • 372 Answers
Hi.
Providing you never put one in of your own The default password is 0000
http://dysonmanuals.llc.nu/
Chris.
Posted on Feb 20, 2008
Misplaced remote control need a remote control
Hi, buy it here on Ebay:
http://cgi.ebay.com/Original-Daewoo-DVD-VCR-Remote-97P1RA2BA5-97P1RA2BA1-/400160550410?pt=LH_DefaultDomain_0&hash=item5d2b6d6e0a
Good luck
Nov 29, 2010 | Daewoo DV-6T955B DVD Player/VCR
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Parental block
Hi! what is the brand and model of your tv?
Sep 05, 2009 | Televison & Video
CHANGE ZONE 0
1. Open DVD tray.
2. Entre 0520 using remote.
3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
4. Enter region code, 0 for complete code free.
5. Close DVD tray.
May 26, 2008 | Daewoo DV-6T955B DVD Player/VCR
Parental code
although my situation was a bit different, part of msimeomix's solution still worked. after entering the password "3308," the screen went blank. i knew this parental code had worked but it would still not allow me to access the "setup" or "menu" options. i pressed "STOP" and then ejected the disc/turned the DVD player off. upon turning it back on and entering the password "3308" i was able to immediately press "PLAY" and it worked. enjoy the movie :]
Mar 23, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DV-6T955B VHS/DVD player problem
It's likely the spindle motor needs to be replaced. You can sometimes get a bit more mileage out of them by placing a tiny drop of WD40 down onto the shaft below the table and working that into the motor.
Bill
Mar 02, 2008 | Daewoo DV-6T955B DVD Player/VCR
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Daewoo DV-6T955B DVD Player/VCR Logo
172 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
