Question about GE GSS20IEP Side by Side Refrigerator
The fan makes a clicking noise. It spins and clicks. Sometimes it runs and randomly it clicks and stops cooling.
    Scholar:
  • 150 Answers
Is this a frost free model ? Could be ice buildup near the fan
Try a thorough defrost with the doors open for say 24 hrs
Posted on Feb 04, 2010
Popping/clicking noise
for window type ac, it must be positioned on level, to avoid flexing it's case.
Jun 04, 2013 | Haier Heating & Cooling
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Loud humming and clicking noise!
You could try looking at the idler pulleys or the air conditioner these 2 things can cause a noise like that, If you have to take the fan belt off make sure you draw a diagram so you know which way it goes, Sometimes you need to do this so you can spin the pulleys by hand to determin if it is one of them.
Jul 28, 2009 | 2004 Chrysler Pacifica
GE GSS20IEP Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
