Info on tv screen
My mother gets a message on her screen every time she changes the channel. It only lasts a short time. It shows Picture format, sound mode and language. It looks part of the menu option but I cannot locate a way to get this off.
  • hawaiiankine Mar 14, 2008
    My Pioneer SD-643HD5 keeps on displaying the "menu" options and then it flips to different inputs. After it's gone to all inputs it stays in input "antenna B"...Please assist! I just got a WII and can't even play it!
    President:
  • 4,402 Answers
Need make and model
Posted on Feb 20, 2008
TV powers up but no picture no menu
If you wish to get some details; check the site linked here. Pull up older posts.
May 24, 2016 | JVC Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Hi, we have no program listings with channel numbers in top screen also no info bar when you change channels... hope you can help, kev
Hi, are you getting a picture or tv show when you have it in cable or dish? some channels don't give info but most of them should.
May 20, 2011 | Televison & Video
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Word Component1 shows up when changing local channels
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
Apr 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
LG 37LT 75 faults Picture freezes everything locks only solution is to pull plug and then restart. Occasionally just get black screen whaen changing channels. Recordings failing due to "time setting error"...
Call out an LG engineer, there are software updates which control the operations of the TV, it would appear that you have an older version & need this to be updated.
Jan 08, 2010 | LG Televison & Video
My 27" Standard TV is showing all channels and movies widescreen
on some remotes there is a button to do this and can only be done using this button-
if you have a sky box or other you can go into services/picture settings and change format here.
if in dout R.T.F.M................lol
Aug 06, 2009 | GE 25GT240 25" TV
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Red screen on LG 44-inch DLP
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Mar 28, 2008 | LG RU-44SZ51D 44" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
