Question about Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 confirmation
How do I set the machine to print a confirmation after a fax has been sent?
Thank you!
  • 15 Answers
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Posted on Feb 23, 2008
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do i get a fax confirmation to print?
Press function then data registration and set/ok.It will say user settings,press the arrow down to get report settings,press set/ok,it will say tx report press set/ok and use the arrows to get output yes,press set/ok and stop!It will print one after every fax u send!Enjoy!
Apr 29, 2010 | Canon FAXPHONE L80 Laser
How to print a tx report with canon L80 faxphone?
Here is a link to Canon for your FaxPhone L80 Users Guide. Reference page 14-3 to access the menus, page 14-5 for report settings, and 14-6 for TX Settings
http://gdlp01.c-wss.com/gds/0300000539/FAXPHONE_L80_Users_Guide_EN.pdf
Jan 07, 2010 | Canon FAXPHONE L80 Laser
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
How do you print on legal paper from memory?
You have sent a fax? Or you have received a fax.
If you have sent it, it's gone and can't be printed.
If you have received it, then you obviously have to put legal paper in the tray, and program the paper size in your system settings to tell the machine it is Legal paper in the tray. However, once again, if it has already printed the fax (likely on 2 pages) then it's gone from memory and can't be re-printed.
May 11, 2009 | Canon FAXPHONE L80 Laser
Canon faxphone L80 will not recieve fax
will it send? It has been put into "manual receive" or "telephone" mode......set it back to "auto receive".
Feb 27, 2009 | Canon FAXPHONE L80 Laser
Don't want a transmission report after each sent fax
On the machine there is a menu button.
the menu can be printed out so you can see all the areas to select.
If you scroll to through the menu, you will find a set up or incoming fax menu.
You need to set confirmation to off.
This will take some time to find the right menu, so be patient with the machine.
Good luck.
Feb 23, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
348 people viewed this question
old marine
old marine
