Question about Zenith DVB412 DVD Player
My disc is jammed and won't come out. - Zenith DVB412 DVD Player
  • 484 Answers
the reason the disc is jammed is because the player did not sit the disc properly.
what you will have to do is;
get a screw driver, open the dvd player, you will find a mechanism that presses the cd down to the lens, you unscrew it too and remove the disc that is jammed in it.
press open to see if it would open up, if it does, then you can screw it back together, but if it does not open then there is a fault with the mechanism that open and closes the player. so you carefully check it out and put it back in order and it would start working.
goodluck
Posted on Feb 04, 2010
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
Dvd won't eject
Someone is going to have to open the unit to see if something is jammed in the mechanism---a disc or something out of position.
Sometimes a gentle nudge will restore operation.
Jun 10, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
CD Player Won't open
There are a few reasons, a broken loading belt, jammed gears, or the timing is out of sync causing the system to lock up.
Mar 20, 2012 | Panasonic SCPM29 5-Disc CD Changer
CD disc in 2003 Holden Commodore won't eject
The problem is a broken loading belt, a split cogwheel, or the gears are jammed.
Mar 18, 2012 | Audio Players & Recorders
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
I have a 2007 Honda Odyssey with the built-in DVD player. Now there's a DVD stuck in it, it won't play and it won't eject. Help!
if you look closely enough there is a small hole on almost any sound system if you do have one put a paper clip in there and wiggle it around a little bit youll hear a click and the system should eject the cd if not then the cd has jammed in there and shattered which means you will have to pay a profecional to take out the dvd and get the disc out. hope this helps and if not well i apologise
May 13, 2011 | Car Audio & Video
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Zenith DVB412 DVD Player Logo
240 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
