Question about Refrigerators
I have a side by side model ACD2238HTS SN#13640707LJ. The ice dispenser door spring seems too strong and you have to reach up with your fingers to pull it open so the ice can come out.
  • 52 Answers
Maybe excessive water dripping from the ice maker that cause the door to "lock-up" a bit. May need to adjust the water flow to ice maker. If that doesn't work, maybe the tempt is set above recommended level and causing the door to stick.
Posted on Feb 04, 2010
My GE monogram ice maker is dropping ice inside the freezer when dispensing
Reach your fingers up into the dispenser from the front and feel to see if the ice dispenser door is shutting all the way when it should be closed. Like my help? What is the model number of the fridge?
APPLIANCE 911
Apr 14, 2016 | GE Refrigerators
Frost builds up on the chute betwen the icemaker and the door dispenser unit.
I need you to confirm your model number. Is MZD2665HE correct? The problem is very likely a broken 12565502 Dispenser Door Spring or more providing you have the correct model number. There may be a kit if the model number is different.Thanks, John Tripp Appliance 911
Jan 31, 2014 | Maytag MZD2665HE Side by Side Refrigerator
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Spring control rod in kenmore model 253.55693400, I think the spring is messed up not letting ice dispense from the door. The auger is turning every thing has power
See if you can run the ice dispenser while the door is open. The auger may be turning but not the "drive blade" that delivers the ice.
Oct 03, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
I have a older modle Hamana 22 refrigerator and it will not dispense ice. The augor just spins and don;t spit any ice out.
Is there any ice in the bin? Check to see if it is clogged with ice, if so, rinse it under hot water. Is the water dispenser working?
Jan 29, 2011 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
I have an Amanda 22 side by side refridgerator with an ice & water dispenser. The ice machine unit's metal rotating rod continues to rotate and continues to dispense ice cubes, although the ice...
Must be the actuator to the ice dispenser is stuck against the micro switch. Like somebaody had a bad day and slammed my acutator around. No model number given so I guess you gotta go with this MANUAL fer a reference.
Sep 13, 2009 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Ice not strong enough to push open ice maker door
twtw7771
You said,
The ice maker door seems to have a tight spring or something because when the ice goes in the chute and then backs up.
The door needs to be replaced because it is bent or out of alignment!
How old is the fridge??
Now a days you have a 1 year warranty!
Or the seal is not tight and air gets inside past the door and then the moisture freezes on the spring.
Sep 20, 2008 | Refrigerators
Ice dispenser spring in door
There should be two slots in the bottom of the panel. Use a screwfriver to pop this out. You will have to unscrew the electrical panel to expose the dispenser area. Be wure to unplug the unit first and be careful not to break any wires.
Aug 06, 2008 | KitchenAid KSCS25IN Side by Side...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
