Question about Xerox Phaser 7300DN Laser Printer
I have a Xerox 7300DN, I had a jam under the Fuser, removed the fuser...replaced the fuser and now I cannot get toner to fuse to the document. I have no spills or excess toner.
  • 583 Answers
The fuser is the heating element and has to get extremely hot in order to fuse the toner to the paper. You might need to remove and reseat the fuser again or replace the fuser if it happened to get damaged from the removal and replacement. This is a direct link to the xerox site for a replacement. You may want to search the internet for competitive prices though.
http://store.officeworld.com/product.asp?q=phaser%207300%20fuser&ShellID=137|37|218|82|39|78|88|120|48|236|245|253|214|179|92|97|7|11|201|60|172|37|19|89|200|18|54|163|74|58|55|52|109|11|215|199|173|168&ProductID=XER016199800&VendorID=1&HiddenShoppingLists=&HiddenCustomerLists=&CartType=&FileID=&gclid=CNPgi6b52Z8CFRJinAodS1XdGQ
Posted on Feb 05, 2010
Paper jams by rolling to the fuser casing. Already replaced fuser module, but still having the same problem.
you must configure the page size, because the configuration jams have a page shorter than the product that you put to print.
Oct 25, 2013 | Xerox Phaser 7300DN Laser Printer
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
Paper james at the fuser, i replaced the fuser but it still jams
Try resetting the nvm settings (Pag 3 of the attach PDF under Support Menu >> Service tool Menu) And the next time you try to print configure correctly the paper settings on the printer and on the print driver. Please make sure your are configuring the paper weight correctly so that the fuser applies the right heat and pressure.
Aug 30, 2010 | Xerox Phaser 7300DN Laser Printer
Ink not drying
sounds as though your fuser has failed.
Oct 29, 2009 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 Jam at Fuser
need more info.
Are you printing more than one page documents? or are you printing a single page... because that would help to know.
The fuser is the most likely culprit. But it could also be a sensor somewhere. The printer has "timing" and when that "timing" is off even a milli-second, it will say JAM. Does it only jam on one type of media, or from only one tray?
need more info.
Sep 16, 2009 | Xerox Phaser 7300DN Laser Printer
Fuser not fusing
do you see the fuser, which is a halogen bulb light up when you print? if not it's bad
Apr 03, 2009 | Xerox Phaser 7300DN Laser Printer
Toner not fusing to the page but fuser is ok
Try the steps on the link below. You can set it too a special paper, also check that there is not loose toner around the contact of the toner cartridges.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=609,E=0000000000024639304,K=4398,Sxi=10,Case=obj(79216)
Niallbt
Mar 26, 2009 | Xerox Phaser 7300DN Laser Printer
Phaser 7300dn Fuser problem
I don't think so. I have had this problem when I'm using a thicker paper and the paper type is set wrong in the printer.
The printer seems to adjust something based on what paper you say is printing. Try pulling the paper out of the printer, then re-inserting it and then choosing a different paper type - one closer to what you are using - or choose the "special" paper type.
This should solve your problem.
Jun 04, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
Jams when duplexing
There is a set of clutches in on the upper back side of the right side door.
The inverter clutch tends to go bad on that cluster.
But if you are replacing one may as well do both. They are electromechinical clutches.
Mar 19, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
