Question about Emerson EWF2004 20" TV
I have an Emerson SD 20 inch TV (its not a flat screen). SN# V12739168 & Model # CR202EM8. We purchased it 2007 (used it only 2 years). Suddenly it would go on and off by its self, then finally it turned off and would not turn back on. Don't know if I can fix it, but I would like to know what the problem is because I have heard that Emerson had a lot of problems with these TV's. I need to be aware of what's wrong, so I don't get ripped off with repairs. Thank you in advance. Jim
    Top Expert:
  • Emerson Master
  • 74,666 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Jun 01, 2017
SOURCE: TV Powered Off, won't come back on
mine did the same thing, I took it to a TV repair store and they said it was a power surge which damaged the power source board. (possibly caused by lightening)
total cost to repair was $70.00 well worth since was only couple years old.
TV is working well.------we'll see for how long????
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: I purchased a used Emerson TV Model 3 CR202EM8 and
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default
(0000) when a power failure occurs. If you forget the
password, unplug the power cord for 10 seconds to restore
the password to 0000.
Posted on Oct 28, 2010
  • 112 Answers
SOURCE: My emerson 20 inch flat
You should be okay just buying any generic universal remote. Any remote requires programming to work with a specific TV, but universal remotes are easily programmable. The instructions included with the universal remote will detail how you program that remote to work with your TV (usually along the lines of simply putting it in programming mode, and pressing the power button until it turns your TV off, and then locking it in)
Posted on Mar 23, 2011
salt56
  • 373 Answers
SOURCE: Hi, I have an
This is a vertical deflection problem. If the picture shrinks suddenly after 20 minutes, then all that is needed is soldering the vertical deflection IC. If you can supply the model number, I can give you a location number in the set if you decide to fix it yourself. Otherwise, it can be fixed by a TV tech and the cost should be well under $100. If it needs the vertical IC replaced the cost of them is about $15 or a little less. Getting it shipped with other items that the tech needs for other sets should buffer the cost as shipping for it alone could run the cost to over $20. Also there is usually a 100 micro farad capacitor that needs to be changed along with the IC. But if you are lucky all you need is it to be soldered with no parts involved.
Posted on May 30, 2011
  • 894 Answers
SOURCE: Emerson TV SN: 011-40401078 Model TC1379 The
Well somtimes buttons break off of tv's because that they are old so its not worth fixing an old tv
now a days most people just buy a new one then instead of fixing the old one. Or you could find someone that fixes old tv's too. To find an old tv like the phiilps one we used to have you would probally need to go to an antique store or and a pawn shop or a secondhand store or a garage sale then. Or the dump because sometimes people put things in the dump like CRT tv's to get rid of them then.
Posted on Aug 22, 2011
What are the remote codes for the emerson cr202em8 tv
if u google tv remote codes it should give u a list of the most common, if its not listed there is a way remotes can be set up through trial & error but its different for each type, it should all be in the instruction booklet for the remote & the codes.
Aug 02, 2015 | Emerson New Original CR202EM8 Remote...
My emerson 20 inch flat screen tv is encased in a dog house for outdoor use. I can't get to the back to see the model number and I want to buy a remote control for it. Is there a universal emerson...
Mar 23, 2011 | Emerson EWF2006 TV
Unable to find the manual; & I need to get another remote control. Bought the tv around three years ago. The model nr. is CR202EM8, Serial nr. is T33751270. Thanks...
Please rate this solution if you find it helpful. Thanks.
Here is a direct link to download the user manual (FREE!):
http://www.manualshark.org/manualshark/files/22/pdf_15075.pdf
As for the replacement remote, the Emerson support contact details can be found here:
http://www.emersonaudiovideo.com/support/contact.php
They should be able to sell you a replacement, alternatively you could buy a universal remote instead. It will probably be cheaper but make sure the remote comes with codes for Emerson TVs!
I'm trying to find a third-party supplier for the remote but it would help me if I knew your location. I will post another message if I can find a replacement.
Hope this helps. BElectric
Oct 14, 2010 | Emerson EWF2004 20" TV
I purchased a used Emerson TV Model 3 CR202EM8 and dont have manual or remote...how do I reset password to access screen to enable me to change to video mode
Sep 07, 2010 | Emerson CR202EM9 TV
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Picture too small on screen
It's a fairly inexpensive repair but with the low cost of new TVs I recommend junking It.
Jan 16, 2018 | Emerson EWL2005 20 in. LCD Television
2 year warranty
the Majority of problems on this and all other LCD TV's are capacitor problems the power pack needs smooth power to work correctly however the warranty should be valid and you need the proof that you bought it and you need to know who to contact about the 2 year warranty it may be Emerson you need to speak with not Walmart. I would contact them next(Emerson), or whom ever the third party repair service is that will cover the Warranty.
hope this helps
Nov 19, 2008 | Emerson EWL2005 20 in. LCD Television
Olevia 42'' flat screen TV
I'm looking for a logic board for a olevia 540i 42 inch
Nov 13, 2008 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
20" digital flat stero tv moel CR202EM8
It sounds magnetised. Is there a magnet near that side... like a speaker?
It probably needs degaussed. Many TV shops have a device that does this, at a cost to you. Also, the set degauses itself for about a second when it's first turned on after being off for a while. So it may go away by itself eventually.
Hope that helps...
Geno
Feb 27, 2008 | Emerson EWL2005 20 in. LCD Television
Emerson EWF2004 20" TV Logo
57 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
