Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
If I turn on my Mag DLP TV (50ML815D/17 ) it starts out dim, then gradually brightens up after a min. it never did that before. is the lamp going?
  • 111 Answers
Yes
Posted on Feb 05, 2010
Dash lights come on with the headlights then shut off
Do you have a dimmer for interior lamps? Like a rheostat, a little wheel that you turn up or down to brighten or dim interior lamps. Usually the instrument cluster lamps brighten and dim the same way.
Can you brighten and dim the other interior lamps?
Apr 17, 2016 | Cars & Trucks
My Mitsubishi HD DLP TV brightness of my picture is dark settings are set properly and brightness is fully turned up not sure what it could be
I think the lamp is reaching the end of its life span. A new lamp will certainly brighten that back up, make sure you buy OEM, I get my clients lamps from Discount-Merchant. If you recently replaced the lamp with an OEM, then its probably a ballast issue, for this is the second most common problem in a DLP TV
Feb 23, 2014 | Televison & Video
Samsung dlp slow to light up when first turned on
if your TV is slow to light up when first turned on its more then likely your bulb. When your bulb start to go bad it will take the TV longer to come on. Try using the bright feature in the menu. If that brightens your TV up then its your lamp going bad.
Thank You for using Fixya and please rate me.
Feb 07, 2011 | Samsung HL-S5087W DLP TV
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox 50" DLP 50ML815D/17 will turn on and broadcast fine, but after about 30-40 minutes of viewing it will turn itself off & a red light comes on. If you feel the tv close to the bulb area it is...
Yes there is a Fan that keeps Lamp cool if it stops running Lamp will shut off it is designed that way to keep lamp cool also if Fans are OK it means Lamp is going out Call Mats 1-800-628-1118 for lamp
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Samsung HLR6167w DLP TV. When i turned it on the image slowly brightened and then heard a noise like a bulb exploding and lost image. We pulled out lamp and its burned out, but now I have a doubt...
After reading up on all possible solutions i found a local shop and bought the lamp. I asked the tech there and he told me that he was 99% positive that it was the lamp .So i installed it and its working thks
Mar 28, 2009 | Samsung Televison & Video
Picture problem
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
202 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
