Question about Aiwa CSD-TD49 Cassette/CD Boombox
I broke the tip off the antenna. Where can I get a replacement?
THat happened to me. If you cant find a place to replace it tkake a metal hanger and insert it into the intena. If you didnt brake off a lot cut the hanger to fit.
Posted on Feb 06, 2010
Tundra antenna removal
You will have to un-install the entire antenna system from the inside.
remove the panel carefully adjacent to the antenna system
undo the bolts and clamps that hold the system in place
you can try and install the new antenna piece without disconnecting the transfer wire that goes back to the radio. But usually you will need to get and install a new system.
just to keep you going in the mean time you could just use a old wire coat hanger "classic" just bend the hook straight and shove it in, you have your sounds back.
all the best
Feb 02, 2014 | 2010 Toyota Tundra CrewMax
Replace antenna
Hi John,here's a link on removing your power antenna.
Jun 06, 2013 | 2000 Nissan Pathfinder
I was removing the antenna, and it broke off. Do
Depending on if your car has a power antenna or not, you may have to replace the whole unit.
The good news is, no, you usually don't have to replace the wires on most GM vehicles. Open your trunk, remove the insulating carpet from the side of the trunk where your antenna is located , to expose the power antenna unit.
This is a stock photo of what the power antenna unit and kit looks likes.
Unplug the electrical connector from the antenna . Unscrew the plastic ring on the outside of the car, where the antenna rest on the body of the vehicle. Pull the antenna unit inside through the hole to remove.
You can usually get a new one for about $89 bucks at Autozone.
Installation is the reverse of remove. Make sure the ignition key is completely off when performing the replacement. Follow all installation instruction on the package. Improper installation could cause rain to leak in your antenna during bad weather and not be water tight.
May 25, 2010 | 1995 Chevrolet Camaro
Hello my antenna broke off what do I need to do
Contact the dealer and either replace the phone if the warrenty period is not over or you may replace the antenna only.
Dec 03, 2009 | Motorola Mobility Tundra VA76r Cell Phone
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Antennae broke
Just go to any radio shack they have lots of antennas
Oct 27, 2008 | RCA RCD110 Radio/Cassette/CD Boombox
Antenna broke and I replaced it
If your not sure what to do at this point you probably should stop right here, however if your bold enough to try this, remove the back cover, I believe there are 6 (six) screws in total, there is also a small metal contact that touches the main circuit board on the back side, that also connects to the antenna, most often a springy piece of gold plated metal attached to a solid threaded nut, where the antenna is attached that fits snugly into the back cover of the phone when the cover is installed the nut is secured and won't fall out. This contact could be on the nut or on the main board if you bent it out a bit to make better contact, you will most likely fix your phone. Cheers!
Mar 03, 2008 | Cell Phones
Midland handheld CB antenna
The connector that's part of the radio, or part of the antenna broke?
Oct 30, 2007 | Radio Communications
Aiwa CSD-TD49 Cassette/CD Boombox Logo
186 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
