Question about Kenmore Washing Machines
Won't work, but it makes a noise. water is in the tub, but won't spin out. kenmore 80's series model 20882 serial cj4610293
  • 32 Answers
Does it fill and drain, but just won't aggitate or spin? If so, power may not be getting to the motor or the lid switch may need replaced. If there is a green light flashing on the circut board attached to the motor, it will indicate what is wrong by the number of flashing lights in a sequence. If there is no flashing light or no light at all, the motor may not be getting power or is no longer good. Some washers have an inline fuse in the wires going to the motor that sometimes gets blown during a power surge. It is easy to replace for only a couple $. Feel the wires coming from the motor (unplug the machine and wait several minutes first) there may be heat shrink tubing around where the fuse is at. Carefully cut away the heat shrink exposing the fuse. An ohm meter testing the line on each side of the fuse will let you know if it needs replaced. When I replaced mine I used a scrap piece of wire to jump them together temporarily until I bought a new pico fuse online. just wrap with electrical tape and plug back into a surge protecter until fixed properly. Hope this helps.
Posted on Feb 04, 2010
Kenmore washing machine 80 series won't spin or add water to the tub
Plug on motor (Multi-plug) may have a burnt out wire as it has different speeds. Remove and check the plug (top comes off). Any burnt wire needs to be cut back to clean copper and refitted into plug.
Dec 07, 2013 | Kenmore Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Will not spin water out kenmore 80 series serial no cl4811664
need model number and more info. does machine make any noise at all
Oct 27, 2009 | Washing Machines
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
