Question about HP PSC 2410 All-In-One InkJet Printer
My scanner won't work. It keeps saying something
My scanner won't work. It keeps saying something like...scan function not installed. Install software. I've reloaded the disk it came with several times....it just won't work.
  • jlmoffa Feb 04, 2010
    I've reloaded the disk that came with the printer...so, it should have replaced what wasn't there. My scanner was working fine. The software was installed properly.
    I appreciate your solution, but .....that just isn't the problem.
  • jlmoffa Feb 05, 2010
    Your right....it can't be Certified for Windows 7! it's a 4 year old all in one printer....and the scanner function does not work at all. I'm now wondering....if I would be better off just to buy a new printer. Cause I spent a lot of time downloading fixes....and nothing has work to date....I'm a little frustrated at this point...and, I don't have that much time to fool around with it.
    Is there a download that would just solve the problem....I'm very tired of all the things I've tried, and other things that other experts have told me.
  • HP Master
  • 12,061 Answers
You most likely have ONLY installed the Printer side of the software... you ALSO need to install the "Scanner" part too. Go to the web site and get the FULL version for your software.
Posted on Feb 04, 2010
  • electronic & computer repair&  servicre
    So the disc that came with the printer is Certified for Windows 7? Is that correct OR?
My scanner hp2410 model can not be shared,can u help me how to share this model
thanks.
Posted on Feb 14, 2010
I can't get the scan function on my canon mp470 to work. It says the drivers for the scanner aren't installed. I have reinstalled the software directly from the manufacturer at least 5 times. It...
Go to Control panel = Uninstall program = remove Canon Mp470 driver... after completing = re-install the programme again.. while installing program you must select "Easy install" thanks...
Aug 27, 2011 | Canon PIXMA MP470 All-in-One Printer
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
It keeps saying that the scanning device is Out of memory/exceeds limits? is this a paperport problem or my scanner? and why all of a sudden? My scanner is a Canon MX860 and has been working great -...
"...till now"
So... what changed? did you install some new software that consumes a lot of resources?
Some update?
Changed something in the resolution? (higher = more memory needed)
check the disk space too, maybe the pagefile is larger than usual.
or, re-install the scanner driver, and PaperPort just to clear things out.
Sep 17, 2009 | ScanSoft PaperPort Deluxe 9...
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Unable to install SCAN functions for HP PSC 1610
If you are having issues using your PSC 1610 on the Vista operating system there is actually an easy workaround using "paint" (I'm using "SnagIT").
Check it out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&product=390315&lang=en
For whatever reason you can't use the actual button on the printer/scanner but when you open paint you can scan the doc from your computer.
Hope this helps!
Mar 27, 2009 | HP PSC 1610 All-In-One InkJet Printer
I can't get my xerox scanner to work
download driver from here:
http://www.arsys-europe.net/Downloads/Xerox/
Nov 10, 2008 | Xerox One Touch 2400 Flatbed Scanner
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
HP PSC 2410 All-In-One InkJet Printer Logo
350 people viewed this question
Seeker5211
Seeker5211
