Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
In computing the IRR, I have two outflows (each yearly); however it will gives me the ERR:Argument when I enter: IRR:(-98000,-98000, {30000},{33}) representing two outflows of 98000, and 30000 a year for 33 years.
  • 2 more comments
  • jchandlerf Feb 05, 2010
    Not the answer - does not work, get error message DIM MISMATCH - meaning the number of elements do not match. So number of years do not match the one 300000 outflow. Try again!
    You are absolutely correct in that the TI does not allow for two sets of cash outflows and the best solution is to use an excell spreadsheet for IRR - which I decided to to. Thanks
    You cannot use two different cash outflows in computing IRR on the TI84. The easiest solution is to use an Excel spreadsheet for computing IRR with two or more variable outputs. Thanks!
  • 291 Answers
IRR on the TI-83 only supports one initial investment, so the argument can only be:
IRR( Initial Outlay, {Cash Flows}, {Cash Flow Counts})
It might be that you could enter an Initial Outlay of -98000 and then have the other -98000 as the first Cash Flow. Then the Cash Flow Counts would be 1,33.
Posted on Feb 05, 2010
  • San Juan Vet Feb 05, 2010
    If using the negative sign in the Cash Flow on the second -98000 won't work (I don't have a TI-83 here to test it), you would just combine the two 98000's together and make it -196000. There are some other ways to go after the IRR with the two investments also. You might use NPV and back into the IRR by going through some iterations.
    If the negative won't work on the Cash Flow, then you just have to use the syntax as written:
    IRR(Initial Outlay, {Cash Flows}, {Cash Flow Counts})
    So for yours:
    IRR(-196000, {30000}, {33})
    If you want to model the two investments you'd need to use a more complicated tool than the TI. Computer spreadsheet would work best.
  • 2,069 Answers
Perform soft reset operation first.
Remove all four (4) “AAA” batteries. 􀂃 Press and hold the [ON] key for 30 seconds. 􀂃 Then put the batteries back into the graphing calculator and turn on. 􀂃 The screen’s contrast may also need to be re-adjusted.
also, please refer to THIS and THIS.
Regards
  • Muzahura Frank Feb 05, 2010
    Ok, go HERE go to troubleshooting (F) check the "resolving the DIM MISMATCH ERROR"
Err Argument with binomcdf(7,0,.25,2) when trying to find No More than 2
binomcdf() takes two or three arguments, but you're providing four. The first argument is the number of trials (7 looks good for this), the second argument is the probability (.25 looks good for this), and the optional third argument is the number of successes (2 in your case).
Try binomcdf(7,.25,2)
Oct 04, 2011 | Texas Instruments TI-84 Plus Silver...
ERR:DOMAIN I punch 2nd, DISTR, down to #10 binompdf(, enter, 15, ",", 95, ",", 13, ) The answer should be 1.3575 or something close to that cause I used my calculator 3 hours ago...
The second argument is a probability and as such must have a value between 0 and 1, yet you gave it a value of 95. That is clearly outside the interval [0, 1].
Jun 15, 2011 | Texas Instruments TI-83 Plus Calculator
How to Calculate IRR?
To calculate IRR and NPVEnter the cash flows as follows, remembering the sign convention:
  • Clear previous data by pressing fXY and fCLX.
  • Enter the cash flow at time zero using # gPV [# CF0].
  • Enter subsequent cash flows using # gPMT [# CFj].
  • If a cash flow is repeated, enter the number of times it is repeated (including the first time you just entered) using # gFV [# Nj]. For example, three equal flows in a row would be entered as3 Nj.
  • When you have entered your last cash flow:
    • If you are calculating an NPV, enter your interest rate as # i (consistent with interval between cash flows) followed by fPV [NPV].
    • If you are calculating an IRR, enter fFV [IRR].
This is an excerpt from http://luna.pepperdine.edu/faculty/mkinsman/calculators/hp12c.html
I did not come up with this solution. Just found it for you.
Apr 04, 2011 | HP 12c Calculator
Casio fx-991ES, how to calculate NPV and IRR
At a blank screen, enter your IRR formula in terms of the variables using ALPHA and ')' for variable X. For example: -1000 200/((1 X)^1) 200/((1 X)^2) ... rest of subsequent years. Then, press CALC. It will prompt you to enter values of your variable (X in this example). Don't worry if there's already a value displayed - this is just the most recent value that has been stored as that letter. Simply enter your value (in terms of your IRR guess) and then press [=]. You will have to repeat this for each IRR guess until you reach almost ZERO.
Feb 11, 2011 | Office Equipment & Supplies
Excel 2007
The IRR function is provided by Excel so you can calculate an internal rate of return for a series of values. The IRR is the interest rate accrued on an investment consisting of payments and income that occur at the same regular periods. In the values provided to the function, you enter payments you make as negative values and income you receive as positive values.
For instance, let's say you are investing in your daughter's business, and she will make payments back to you annually over the course of four years. You are planning to invest $50,000, and you expect to receive $10,000 in the first year, $17,500 in the second year, $25,000 in the third, and $30,000 in the fourth.
Since the $50,000 is money you are paying out, it is entered in Excel as a negative value. The other values are entered as positive values. For instance, you could enter –50000 in cell D4, 10000 in cell D5, 17500 in cell D6, 25000 in cell D7, and 30000 in cell D8. To calculate the internal rate of return, you would use the following formula:
=IRR(D4:D8)
The function returns an IRR of 19.49%.
The ranges you use with the IRR function must include at least one payment and one receipt. If you get a #NUM error, and you have included payments and receipts in the range, then Excel needs more information to calculate the IRR. Specifically, you need to provide a "starting guess" for Excel to work with. For example:
=IRR(D4:D8, -5%)
This usage means that the IRR function starts calculating at –5%, and then recursively attempts to resolve the IRR based on the values in the range.
Jun 09, 2010 | Microsoft Office Professional 2007 Full...
Im using the geometricpdf and everytime i plug in numbers and press enter it gives me err:argument. How do i fix this?
Make sure the first argument is a number between 0 and 1, inclusive. Make sure the second argument is an integer or a list of integers.
May 10, 2010 | Texas Instruments TI-83 Plus Calculator
Computing IRR calculator goes blank and outs Error 7
I belive this will fix the problem i was sitting here having the same deal waiting and waiting..then bam error 7 then i fixed it so thought i would put what i did.
go into your CF and delete all the unused CO times..for instance if your using 3 periods...delete all CF05 and F05 the last one should be C04=0 and F04=0 make sure your NPV is the same after messing around..then try to compute IRR popped up in 2 seconds for me.
word hope this helps u all ***420*** :0
Nov 21, 2008 | Texas Instruments BA-II Plus Calculator
Calculating out npv and irr
Are you using the finance app?
[APPS] [1] [ENTER]
For NPV, choose "7:npv("
Then use:
npv(interest rate, cost {cash flows}, {frequencies of cash flows})
For IRR, choose "8:irr("
Then use:
irr(interest rate, cost {cash flows}, {frequencies of cash flows})
Jul 25, 2008 | Texas Instruments BA-II Plus Calculator
Quaterly IRR
if your analysis is based annually, yes. if it is based quarterly, then you have to raise the derived irr to the 4th power (4 consecutive quarters) to arrive at the annualized irr.
Jul 04, 2008 | Microsoft Excel for PC
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
May 13, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
192 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
