Question about GPS
Device will not power up. WHY? - GPS
  • 12,061 Answers
There are a few reasons why. It may simply be a "Flat" battery. It maybe an internal "Microprocessor" problem. It may simply need to be "reset".
Posted on Feb 04, 2010
What is the code for a GE remote
turn device on (tv etc)
hold power and device button until remote blinks
release both buttons
press power repeatedly until device shuts off
when device shuts off push device button on remote to save setting should blink again
press power test that remote operates device
Nov 10, 2016 | GE Televison & Video
Do someone have a vcr remote code for kaon ksc 570?
Turn device on (tv etc)
press power and test that remote operates device
Nov 10, 2016 | Televison & Video
How do I get my nextbook tablet out of safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Nov 04, 2015 | Nextbook Tablets & eReaders
I CAN NOT CHARGER MY DEVICE IN USB
USB connection cables comprising of ports on computer telecommucnations devices are versatile outlets to managing multimedia. First the USB port on the device makes device to device connection where resoruces can be shared among several function requests. Second, the USB port on device least allows to derive power charge from another device only has to be attained from power outlet. For example, while a device is plugged into another device for media resources sharing is least like to attain power charging simultaneously. First use the USB port to power charge from an outlet to attain required functioning status. Circumspectively, the devices that have USB ports has several functions either as media resource sharing also for power circuit charging only each separarete process is attained where it is impossible to power charge a device while using the same port to derive functionality.
Feb 18, 2011 | Computers & Internet
My sony wega trinitron srs bbe won't power on
Power on is indication of current supply malfunction. For example, the battery supply requiring recharge before powers back on again once depleted of supply at prior usage. A completely depleted device battery would require full battery recharge before any images are displayable once more. Ascertain the full charge duration requirement to perform battery charging. Meanwhile, inspect the device for power device maladjsutments. For example, the battery compartment may have malalligned due to impact. verify that each compartments contributing towards powering up is in place. Open battery compartments to ascertain integrity. Thereafter, plugging device to power source should restore default power functioanlity soon after full charge is acheived. Also, the process of powering on the device may require continously pressing on extensively to acheive restore display for images. Refer to the device user manuals for diagnostic on power malfcuntions. Consult technical experts when required. Good luck
Jan 08, 2011 | Televison & Video
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
How do I reset it?
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware UpdaterSTEP 1 – Reset the device
This is what I found on a Frequently Asked Questions page #13. The link is here below
http://www.sansa.com/support/sansa_view/faqs
You may need to scroll through to the one I found. Hope this help :D
Jun 06, 2009 | SanDisk Sansa e250 MP3 Player
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Garmin Nuvi 300 does not switch on. The wrong charger was used
    1. If using the power/data cable to power your device:
    1. Make sure you have power at the source it is connected to.
    2. Check the fuse in the power cable.
    3. Use a volt meter to test the end which plugs into your device (the manual for the device should show which pins are power and ground. Make sure you are getting at least 12 volts of power. This will ensure you are getting full power through the cable and determine if the cable is faulty.
    2. If using a 12 volt cigarette lighter adapter:
    1. Check the fuse in the adapter.
    2. Make sure the cigarette lighter in the vehicle has power by connecting another device with a different 12 volt adapter if possible.
    3. Make sure the metal tip on your 12 volt adapter is still connected
    3. If using batteries:
    1. Make sure none of the battery terminals are still connected to the device.
    2. Try new batteries.
    3. Make sure the batteries fit tightly inside the device. This will ensure the battery terminals are not loose and you have good contact.
    4. If you are powering the device on the built in lithium ion battery:
    1. If you have a power cable for the device, plug it into a power source and see if the device will power on with direct power. If it powers on, check to see if the battery is fully charged.
    2. If it is not, let the battery fully charge and then try to power it on with just the battery.
    Sep 26, 2008 | Garmin GPS
    GPS Logo
    15 people viewed this question
    Top GPS Experts
    Are you a GPS Expert? Answer questions, earn points and help others
