Question about Samsung HLR6768W 67" Rear Projection HDTV
Loud noise, line on the left side, no color - Samsung HLR6768W 67" Rear Projection HDTV
  • Samsung Master
  • 610 Answers
It sounds like the color wheel has fallen apart and will have to be replaced by a technician. The line could be from the color wheel or from the light tunnel. You can call 1-800-samsung for the nearest service center.
Posted on Feb 04, 2010
My XEROX 6180N printer has vertical white lines running on left side of page and also has starting making loud squeaking noise while printing? Any ideas?
Try a different cartridge. While line typically means that no toner is being applied to the drum in that location. Would also explain the squeaks.
Sep 02, 2015 | Xerox Phaser Office Equipment & Supplies
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
Loud noise in front/side. When make a sharp turn
most likely a cv axle if it makes popping noise in turns
Jul 07, 2010 | 1991 Subaru Legacy
Loud humming noise and black line
Sounds like the color wheel has broken. Remove the color wheel and see if its broken. Usually a broken wheel will cause those symptoms.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Loud and Grinding noise
I had the same problem, except my 9420cn is just over 1 year old. The parts life section says everything has atleast 75% of it's life left. I checked the toner cartridges and found the gear on the cyan cartridge was jammed.
I replaced it and no more noise....
Mar 28, 2008 | Brother MFC-9420CN All-In-One Laser...
2 multi color lines loud vibration noise
If you have changed the OPC drum and cleaned the entire insides of the printer after taking out the toner cartidges and OPC drum.You need a tech to look at it. The fuser is probably messed up from loose toner.
Sep 04, 2007 | Minolta magicolor 2300W Laser Printer
Samsung HLR6768W 67" Rear Projection HDTV Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
