Question about Dell Latitude D600 Notebook
Computer has just shut down and says needs configuring?
    President:
  • 949 Answers
Usually this is a sign that you just had windows updates installed and it is configuring them.
See if it starts, if not restart it and don't shut it down, if this keeps doing this, then see if there is any code or anything else it says and post it,
or just use system restore, and restore it to a earlier date.
Posted on Feb 04, 2010
Configure acer sk 9610 keyboard
shut down computer are if computer is shut down unplug keyboard from back of computer, restart computer and after the desktop is up and running replug keyboard back into the computer.The computer will then search for the correct driver and install it.
Apr 16, 2014 | Computers & Internet
Updates not configured. reverting changes... whenever i shut down r switch on it is coming like "configuring 1 of3 updates...." after a some time updates are not configured well.reverting changes" . am...
indicates a register problem
run the recovery disk
or
in the search box under the programs list type in CHKDSK and enter
This program runs the entire library and fixes and rectifies any problems in software , file and folders --takes several hours
Dec 06, 2017 | Computers & Internet
I turn my computer on and the screen is black, what can I do?
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Jan 10, 2011 | Sony Vaio P VGN-P530H Netbook
My monitor turns off every 2 minutes, even when you re power the monitor it will just shut down randomly. anybody knows whats wrong with it? and how much it will cost for repairs?
does it always shut down every 2 minutes? or is it "random" like you said? i ask because it can be configured to turn off as desired (that is if it is not used).
http://www.tothepc.com/archives/configure-your-computer-to-turn-off-automatically/
i think this website might be able to help you
Dec 16, 2009 | AOpen F2715 (Black) LCD Monitor
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
I have a HP and use Vista. My computer has worked fine all day, then it froze I shut it off and when I turned it back on the hp sighn came on then a black screen with a small blinking light. I went into...
I copied this from windows help and support if this don't work then you will have use your restore disk. mysleuth
Start the computer using the last known good configuration To start the computer using the last known good configuration
  1. Print these instructions before continuing. They will not be available after you shut down your computer in step 2.
  2. Click Start, click Shut Down, and then, in the drop-down list, click Shut down.
  3. In the Shut Down Windows dialog box, click Restart, and then click OK.
  4. When you see the message Please select the operating system to start, press F8.
  5. Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
  6. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
note.gif Notes
  • Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
  • When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • NUM LOCK must be off before the arrow keys on the numeric keypad will function.
Apr 28, 2009 | Compaq Presario 5000 PC Desktop
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Shutting down incorrectly
Hit F8 while booting up then start the computer using the last known good configuration. If this helps please rate me if not let me know so I can help. mysleuth
I copied this from WinXP Help and Support you should be able to restore your system.
note.gif Notes
Mar 11, 2009 | HP Compaq Presario SR1830NX PC Desktop
Media Center "video crash" after installing SP3 dhclaytonphd@msn.com
(1)The first thing I would do is download video driver from dell.com/support. (2)You can remove SP3 and see if that works. (3) If not you can Start the computer using the last known good configuration I copied this from WinXP Help and Support you should be able to restore your system. If this helps please rate me if not let me know so I can help. mysleuth
note.gif Notes
Mar 11, 2009 | Dell Dimension E510 PC Desktop
Computer is hung up in a loop and can't restart.
Start the computer using the last known good configuration I copied this from WinXP Help and Support you should be able to restore your system. If this don't help you will have to run windows setup and repair or install. mysleuth
note.gif Notes
Mar 09, 2009 | Gateway 838GM (RB838GM) PC Desktop
Dell Latitude D600 Notebook Logo
35 people viewed this question
Alun Cox
