Question about Dryers
The appliance is not drying and I have changed the heating element
  • Dryers Master
  • 12,061 Answers
In this case, it is either the "Sensor" or you have a Microprocessor fault.
Posted on Feb 04, 2010
Whirlpool Duet Steam is heating up to dry any clothes
Sounds like the heating matrix/element has failed, or some other internal component has failed. If you can return it under warranty, do so. Otherwise you'll have to pay an appliance repair engineer to repair it for you.
Jan 21, 2014 | Washing Machines
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
Hello, I have Kenmosre 90 series dryer. Did a load ealier today, and it was fine. Went back to put another load in and realised NO heat was on, absolutley no heat in the dryer, the air inside is room...
you may need a heating element. You can go to your locale appliance store and buy the element & install it yourself . Just make sure you take All your dryer info, (etc; the dryer model, make, yr & the serial # ) this info is easy to find, its located inside the dryer door. Just call around your locale area and ask them how much it is for the heating element, for your dryer. It should be rather cheap compared to the cost of Kenmore appliance company coming out to fix it for you. The heating element is rather easy to install. I have installed a few in my own dryers and in my hot water heater.
Thank you.
Sincerely,
cat2868
Jan 28, 2011 | Kenmore 62802 Electric Dryer
The appliance works but does not heat sufficiently to dry the clothes. The appliance can run for ages but not dry the clothes?!
You will need the thermostat or heating element replaced. if you need instructions on how to do this please post back with make, model, and model number.
Dec 01, 2010 | Dryers
Dishwasher does not heat up and dry.
Just call a repair man and in sometime u can already use ur dishwasher!
Oct 22, 2009 | Dishwashers
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
NOT DRYING ONLY ROTATING
Check the thermal fuse at the back. If thermal fuse is OK, then there is need to test Element and temperature sensor with a multimeter. Check also if fan is working.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 29, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Condenser dryer
doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Apr 09, 2007 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
Top Dryers Experts
