Question about Sewing Machines
My thread is coming out lose on the bottom don't know what to tighten.
    Scholar:
  • 150 Answers
Try re-threading the shuttle correctly
Posted on Feb 04, 2010
My stiches are coming out too loose
Sounds like a tension problem. Let me give you instructions for adjusting the tension on anysewing machine. Be sure to have a scrap piece of the fabric you are using andthread the top of the machine with a different color of thread than thebobbin-it'll make it easier to see what's going on. Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
Jun 16, 2011 | Bernina Activa 140
My little friend has a mini style elements sewing machine, the thread tension seems to be the pr4oblem, how can i adjust both the top & bottm threads, also we are sure we have it threaded correctly,...
Let me give you instructions for adjusting the tension on any sewing machine. Be sure to have a scrap piece of the fabric you are using and thread the top of the machine with a different color of thread than the bobbin-it'll make it easier to see what's going on.
Jun 07, 2011 | Sewing Machines
I have cleaned and oiled the machine. Re threaded it several times, tried to adjust the dial in different directions, still to no avail --- the top thread shows up on the bottom of what I am sewing. ...
You need to fine-tune the tension. The instructions I'm going to give you will work with any sewing machine and can be repeated for any type of fabric you sew in the future where this happens. Use a scrap of the material you're sewing with that's a few inches long and a couple of inches wide. Also, it helps if you use different color threads in the top and the bobbin thread.
May 31, 2011 | Janome Memory Craft 3000
Consew 220. I just bought it. No paperwork came with it. What is the proper way to thread it? Other adjustments necessary? Suggestions? Thanks for your help!
You can find a visual guide on the proper threading of your machine at http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Consew_Sewing_Machine_Threading/consew_210_220_threading_diagram.htm. What other adjustments are you thinking of? If you have loose thread on the top or bottom, you would need to adjust the tension. The best way to do that is to start by having a different color thread in the top and in the bobbin. Then this little lesson on tension works the same with any machine.
May 29, 2011 | Consew Sewing Machines
The stitch on the bottom of the material is very loose and is bunching and looks terrible, the top thread keeps skipping and breaking, Ive fiddled with the tension and still having problems
Let me give you a general lesson on adjusting tension that will work for any machine. I suggest you thread the top of the machine with a different color thread than the bottom so that it's easier to see what adjustments you need to make.
May 22, 2011 | Brother XL-5130 Mechanical Sewing Machine
Stich is loose on underside of fabric
You probably need to adjust the tension. Let me give you a general lesson in adjusting tension that works for any machine. Also, I suggest you thread the top of your machine with a different color thread than the bobbin-it makes it much easier to see what is going on.
May 18, 2011 | Toyota Sewing Machines
I can't adjust my tension correctly. The stitch looks fine on the top and is a bundle of thread on the underside. Help.
Let me give you general instructions on adjusting machine tension. Make sure you thread the top with a different color thread than your bobbin so it's easy to see what's going on.
May 17, 2011 | Singer 3116 Simple
What is the way to get even top and bottom thread tension. the machine is a Husqvarna 2000 6440
Let me give you a quick lesson in adjusting your tension. First, thread your bobbin and your upper thread with two different colors-it'll make it easier to see exactly what you need to adjust.
Thread your machine with the presser foot UP. The disks that control the tension (thread goes through them) are tightened up if the foot is down.
Change the machine tension with the presser foot DOWN. Because the disks won't be engaged (see above) if the foot is up, the disks won't move.
Start at the middle setting, 3. Go up to tighten, decrease to loosen. Each machine is different, even 2 different machines of the same model. The best thing to do is start at 3 and use a different color in the top and bobbin thread so you can easily see what changes to the tension do to your stitches.
Now use a straight stitch a sew 3 or so inches. Take a look at the top and bottom of the fabric. You don't want to see any (or at least not much) of the other color showing from the other side.
Loops on the bottom of the fabric means you need to tighten (increase) your top tension. If you're stitches on the bottom are causing puckering, then you need to loosen you're top tension. For the most part, you really don't want to touch your bobbin tension-leave that to a repair technician. The factory setting shouldn't be touched except by someone who really knows what they're doing.
Keep sewing a few inches at a time until you have the results you want. Now you're tension is where you need it!
May 10, 2011 | Husqvarna Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Nov 22, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
