Question about Refrigerators
FREEZER COILS FREEZING UP AND FRIDE IS GETTING WARM. MELTED THE ICE FROM COILS, MELTED ICE FROM THE OPENING BETWEEN FREEZER AND FRIDGE AND RAN GREAT FOR ABOUT 2 DAYS. nOW IT IS FREEZING UP AGAIN. SEAL IS TIGHT, NO AIR SEEPING OUT.
    Genius:
  • 1,122 Answers
You might have a bad freezer heating element,or bad defrost timer or badheater on off terminnator
Posted on Feb 04, 2010
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
Frost free fride freezing along back panel
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 03, 2011 | Refrigerators
Hi fridge was not staying cold so i looked at the coils in the freezer and they were cover with snow(ice), I melted the snow and ice and it worked good for almost 2 weeks then started getting warm again...
Its definatly a defrost problem. The reason it stopped cooling is because there was no air circulation do to the ice build up. For the most part the part you'll need t replace is called an adaptive defrost control, the part number for it is 12002104. This part is located in the refrigerator side of the machine, above the heading so you'll be taking the hole top down to put it in. Take your time and it won't be hard.
Nov 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
Freezer is freezing up, then freezer and fridge warm up.
hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Oct 30, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
