Question about Microsoft Xbox 360 Console
Will not turn on ps is good
Will not turn on power supply is good
  • 340 Answers
Are you using a plug and play kit, if so disconnect the cable and try again.
If that does'nt work have a look inside the usb ports to the right of the console under the big flap,look for damage or bent pins, this will short out your console so it won't turn on, just make sure non are touching.
If thats not the fault iy may be a resister fault, you would be best to book a repair with a pro repair center.
Remember thumbs up if this helps.
Posted on Feb 04, 2010
  • Microsoft Master
  • 2,404 Answers
If the power supply is good and the 360 won't turn on then try another working outlet. If that doesn't work then the main board in the 360 is bad.
Al-a250atx does not power on
replace power supply if it's faulty
Nov 13, 2013 | Computers & Internet
I have an old Hp Pavillion 505n desktop computer. Has been working fine for years. Awhile ago it would not turn on at all. The disk drive lite would flash on and off a few times then nothing. I removed the...
That 4 pin plug generally supplies power to the processor. It depends on the processor type. Unfortunately the next step in troubleshooting is to replace the motherboard or the processor and there really isn't a good way to know which one first.
Jul 29, 2011 | Computers & Internet
No power supply power out, ps fan not coming on, fuse is good
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Dec 30, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Short burst of power
Most likely you have a bad power supply, or a short or overload that causes the power supply to shut down. You will need a DVM (digital volt-ohm-meter). Using the DVM and the instructions on the PS, unplug all PCI boards and all wires on the HD's. There should be a point where the PS will not shut down. Then you will have to install all the connections one by one, until the PS shuts down. You will have to turn off the computer for each of the connects and each of the re-connects or you are exposing your computer to a great danger. CONSTANTIN (arzconst)
Jul 31, 2009 | EliteGroup KM400-M2 Motherboard
Won't turn on - PS light on but no PS fan
Surely sounds like the power supply is in need or replacement, or fuse replacement at absolute least.  the fuse that you will be in search of will be located inside of the power supply unit.  Use caution when working inside the power supply.  If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply.
Regards,
Joe
May 07, 2009 | Computers & Internet
AA8 DuraMAX won't power up
if you are sure that the ps is ok replace the motherboard
Mar 21, 2009 | Abit AA8-DURAMAX Motherboard
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
