Water leak water condening inside room
    Problem Solver:
  • 13 Answers
Check your drain hose it may be clogged
Posted on Feb 07, 2010
Ge Monogram all in one refrigerator model zir36nmdlh is leaking and freezing food
There is a heater element that helps to defrost the coil, you may need to replace it.
May 04, 2014 | Home
Tip
Water leak in split a/c.
When compressor pumps the vapor of the freon passes through condenser coil pipelines where the heat removed by fan and becomes low pressure low temp and then travels as liquid. By removal of heat in the room again the freon get vaporized and sent to compressor. In this cycling if your indoor coil is dust blocked the room heat can't be removed. resulting this the liquid becomes forming ice over the coil. And when it cut off by coil temp, the fan only will work and ice get defrosted and water spray thr' vent.Due to coil block and makes airlock to drain pipeline. Resulting to water leak inside.To avoid water leaking service your a/c periodically.
on Jan 10, 2011 | Heating & Cooling
Excessive collection of water in front of unit when running air
it is posibille to be broken the drain condens,or many dirty in the inside uni twhere is colect the condens
Dec 04, 2013 | Heating & Cooling
Maytag refrigerator model number MSD2735GR - Leaks from freezer. Ice build up around condensation drain hole. I have unthawed twice and unclogged ice from the condenate line. Keep having same problem.
I suggest you empty the freezer. Then use a hair dryer to copletely dry the entire inside of the freezer then make sure everything you put back in is dry. I had this same problem and this worked for me. Just had to much humidity in freezer.
Jan 01, 2012 | Maytag MSD2732GR Side by Side Refrigerator
I have a GE Btu 5000 and you can hear water inside of it. How do i fix it?
You're supposed to hear water inside it. That shows that it is removing the humidity from the air. If it is leaking into the room, tile the outermost end down about 1/2" lower than the inside end.
Jul 07, 2010 | GE Quiet-Aire Ductless Split System Air...
Leaks water into room
Try tilting the a/c to the back. In most cases the manfacture will seguest that the unit be tilted to the back slightely (no more that 20 degrees). That is what I would try. If that dont fix it let me know and we will try together and solve this problem. Good luck
Aug 24, 2009 | GE Heating & Cooling
Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Jun 08, 2009 | Panasonic Room Air Conditioner CWXC104HU
Tumble dryer awz650.over heating
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
STOP!! BEWARE ,THIS A FIRE HAZARD! HUNDREDS OF HOUSE FIRES A YEAR OCCUR FROM THIS PROBLEM
unplug it and call,SERVICE
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool Dryers
Water leaking below the freezer unit
I have a GE side-by-side refrigerator/freezer and have had the same problem with water pooling at the bottom of the freezer and running onto the floor. The solution is easy. There is a drain tube just behind the pull out drawer at the toward the bottom of the freezer. When that tube get's plugged, it does not allow for water to drain out into the drain pan. To solve the problem, first remove any ice build up from the bottom of the freezer and from around the drain tube opening. Then pull the freezer away from the wall and remove the cover from the bottom of the appliance. You will see a drain tube on the bottom right side. This is the tube that is plugged. Simply use a turkey baster to squirt warm water down the tube from the inside of the freezer (or anything that will allow you to squirt water into the drain tube) until water flows from the tube into the drain pan. It usually takes me 3-5 times to clear the line and once it is cleared, I run a little additional water through the line to make sure it's cleaned out well. The repair is simple and only take about 15-20 minutes.
Apr 17, 2008 | Refrigerators
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
