I have a bosch washing machine model wfl2450. how do i replace the heater element on it. Is it hard to get at it. also the machine will not rinse and spin in mid cycle; but will spin and rinse when you do it manually.i think its a new programmer. what do you think.
    Brigadier General:
  • 3,917 Answers
These are very easy and quick to replace, just remove the top, and there are 2 Philips screws retaining each one. The terminals are just standard spade push fit. See the one on the right. To test these with a meter, REMOVE POWER FIRST, PULL OFF SPADE CONNECTORS. This one had gone open circuit, but they can short to the metal body, which will be earthed, and will continue to blow the plug fuse or breaker, unless the wires are disconnected. Normal reading for a 1000 WATT example is 50 to 55 OHMS across the spade terminals. After you disconnect and tape up the removed spade connectors, the machine should function on WASH CYCLES ONLY until you get your spare. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 04, 2010
How to fix a heater zwg 7120p
You will have to purchase the heating element which for your model might look something like the one shown on this site.
Washing Machine Heating Element with Sensor
The instructions to replace this should come with it.
If not then try to download instructions from here which is usually similar for most European front loaders like yours.
How to replace washing machine element front mounted in Bosch washer
Sep 02, 2014 | Zanussi Washing Machines
My bosch classix 2100 washing machine takes 3 hours to finish a 30 degree wash.is this normal?
If it gets stuck on 1 minute for a long time, it is possibly the heating element which needs replacing. They can get covered in scale in hard water areas and stop working. Replacing the heating element in my Bosch Logixx solved the problem.
Sep 27, 2013 | Bosch Washing Machines
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Excell washing machine programme fault
Jun 28, 2009 | Bosch Washing Machines
Element Needs changing Bosch WFO2466
you should never have to remove drum to replace element. not familiar with this machine take back off and have a look or it will be at the front of machine
Jun 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch washing machines element
depends on model. most washer elements are fixed by a centre nut (10mm)which undo and then prize out the element - takes 5 mins
Mar 19, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
