Question about Kenmore Washing Machines
My model # is 417.89875100 - i need to know the voltage it uses! 120? 220?
    Problem Solver:
  • 16 Answers
A 120-volt, 60-Hz., AC-only, 15- or 20-amp, fused electrical
supply is required
Here is a link for your owner's manual
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0409319.pdf
Posted on Feb 05, 2010
Tail lamp is not working?
Yea , so ! what is it you would like to know ? What make , model and year vehicle do you have ? Do you know how to do automotive electrical circuit testing ? How to read a wiring diagram ? How to use a DVOM - digital volt ohm meter ? Checking for B+ voltage at the tail lamp would be a good first step . No B+ voltage ,work your way back to the Light switch till you find B+ voltage . If there is B+ voltage , test the ground side . Voltage drop testing ! Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Feb 06, 2017 | Cars & Trucks
How to check injectors for voltage
Use a test lite. If two wire connector for fuel injector, one is voltage the other is ground. With some makes and models, the voltage goes hot with key on and the computer supplies the ground. You may need to use a noid lite, see if it will flash, engine cranking. My info is very basic, because I don't know your year--make--model?
Nov 08, 2016 | Cars & Trucks
How do i know wich wire is wich voltage
You will need a multimeter that can test DC voltage. Power supplies don't always use the same color coding system so depending on the model it's possible your values will be different.
That being said the ATX standard is the most likely and I have attached a picture of the pinout and color chart.
Feb 06, 2016 | Computers & Internet
Got sound but no picture
If the model number listed here is correct either no high voltage is present or filaments to the 3 picture tubes it uses are not lit.
If a different model let me know, this one here is prone to all sorts of bad solder connections around the high voltage transformer and sometimes resoldering those cures problems
12_14_2012_5_31_33_pm.jpgtypical high voltage transformer
Dec 14, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to know the voltage of the speaker for ac adapter matching
The speakers may have a label that has the voltage printed on it.
You can check the Bose WEB site for the specs of your model speakers. You need to know the polarity of the connector, if you get it wrong you could destroy your speakers.
You may need to contact Bose support if the specs do not help you.
Jun 14, 2012 | Bose Companion 2 Computer Speakers
I need to know the voltage of the motor used in DP300 MODEL
Most motors run at 5 volts if you are talking about the pladder motor that the disc sits on. if you trick the switch to turn on you should be able to measure the voltage.
Mar 27, 2012 | Televison & Video
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
Input Voltage on WD MyBook and Elements
NO, they are not all multivoltage. Especially if you bough *** in the states as a 110v. You will need to have an external voltage adaptor in use.
Jun 13, 2009 | Western Digital My Book Essential Edition...
Need info about circa1950's Rockwell/Delta 8" jointer
I can't help you with the knives, but I can help you with the motor - you need to find the plate on the motor with its specs. If it has a horsepower rating, just replace with the same horsepower. If it doesn't show a horsepower rating, I need the amperage (FLA), and the voltage, I can determine it from that. Please get back to me with both the horsepower rating and the voltage and FLA if you can, and tell me what voltage you are going to hook up to.
Mar 16, 2009 | Masonry Tools
Washing Machines Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
