Question about RTO Pelican Monaco Pedal Boat
Can hear water in the hull; is there a quick drain and where is the most likely area it is leaking from, is there a kit? model H27.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
In the nose of the boat right next to the handle theres a funny looking switch if you stand the boat on its nose and flip the switch it will let the water out.
But...in my personal opinion it keeps the hull a little lower to the water and the paddles deeper...
Posted on Feb 08, 2010
Where are the drain plugs situated on a T Cat boat
has to be out on the rear hull area
below water line or deck platform
upgrade hull with
aftermarket stainless steel or brass systems
wise to have a bilge pump
and carry bailing buckets
9f16875a-8021-465a-81f2-8f6b06be53e4.jpgindex-cvxygyvu0vydc25j522ljeey-4-2_0.jpgst-cvxygyvu0vydc25j522ljeey-4-3.jpg
Mar 31, 2017 | Boating
How do I locate where water is leaking in from - 1983 Olympic - water is showing up on the cabin floor
livewell hoses have a habit of leaking.if you could leave it in and put the boat on trailer you might see where it leaks back out.
Sep 16, 2014 | Boating
Water in hull of bass tender pro
Find the leak and patch it. Use a good marine epoxy system with a sheet or two of fiberglass cloth laid-across the crack. Be sure to sandpaper the area thoroughly with rough paper. If you can't find a leak or crack, fill the hull with water and inspect for leak. Repair after.
May 20, 2014 | KL Industries Basstender 10.2 Fishing Boat
Refrigerator leaks alot of water from freezer area
Most of the time you have a clogged/frozen drain. If this is a freezer on top model, you need to remove the back wall or floor and defrost the drain with warm water or hair drier ... I find that warm water and a turkey baster works best.. just keep shooting the water down the drain hole until it takes the water down on its own. If the problem returns sometimes you will need to install a drain heater or conductor kit. If this is a side by side model the repair is about the same ..just remove the freezer back wall and melt the ice and flush the drain.
Mar 08, 2014 | Westinghouse Refrigerators
I've had my 2013 Ride 115 for a month and half now. I took it out on a small calm lake and paddled for about 1 1/2 hours. When I went to put it on my trailer, I couldn't lift it because of all the water...
My first thought would be to check the drain plug which is located toward the back of your hull and quite possibly at or below the water line. Past that, there's a leak somewhere and you should take it to the dealer as it should still be under warranty.
Aug 12, 2013 | Wilderness Systems Ride 115 Kayak
Why does the hull fill with water on a 1989 waverunner 500?
more than likely the seal around the intake shoe and or ride plate has been damaged or is missing. the factory uses a neoprene type double sided tape in between those pieces and the hull, next would be to look around the rear of the exhaust system while running on the hose to look for water leaks. Also is there a flush kit installed and is the cap on it?
Aug 30, 2012 | Water Sport
I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
May 15, 2010 | General Electric WHDSR209DWW Top Load...
My 1997 polaris jet ski keeps taking in water? what could this be??
Unplugged water tube, cracked water tube, bad drive shaft hull seal, hole/crack in the hull, cracked water box, broken exhaust jacket water seal, water tubes plugged in incorrectly, no cap on flush kit, broken fitting on motor,etc. Dry out the boat take off the seat and place it in the water and look to see where the water is coming into the hull.
Sep 07, 2009 | Polaris ATV
Our whirlpool refrigerator is leaking water out the back. We have turned off the water source but there still appears to be water leaking from somewhere. Everything is still frozen and the freezer is at...
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 11, 2009 | Refrigerators
Crack in clear blue hawaii molokini hull
Use a fiberglass repair kit, available at most hardware stores. Use an overlay prior to patching so you don't develop a soft spot in the hull.
Jun 15, 2009 | Clear Blue Hawaii Molokini Kayak Cbh57702
RTO Pelican Monaco Pedal Boat Logo
593 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
