Question about NRS Brondell Swash 800 Bidet - Electronic Toilet Seat - Elongated White
Swash 800 wands stopped flushing.
The last time the wands worked, the shut-off mechanism (when no one is seated) also didn't work (for the first time). Water sprayed out uncontrollably. Since then the wands are unresponsive to commands from the remote.
Hi There,
Just call Brondell toll free at 888-542-3355 and they we can trouble shoot the problem. If it's in warranty, repairs may be covered and outside of warranty, discounted servicing is available.
Posted on Feb 05, 2010
Brass drain valve not working.
they get stopped up leave pressure on tank don't shut cutoff off hook up hose and run to outside then open drain valve with pressure on it for a min. it should flush.
May 03, 2016 | Water Water Heaters
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
Sep 13, 2012 | General Electric GE SmartWater Household...
I have a Rheem 41VRP50N water heater. The water I am getting is luke warm on a good day. The burner fires up when I turn the thermostat to the highest temperature only. I drained the unit and flushed...
This condition can be caused by 4 different problems, or combination of these problems.
Good indicator would be to check temperature of water inside tank.
Put bucket under TP overflow tube and release water into bucket, then use cooking thermometer to gauge temperature. Stand back from scalding water that can shoot out of overflow.
If tank temperature is 120-130:
1) Crossover is suspect:
http://waterheatertimer.org/Crossover.html
If tank temperature is low:
2) Bad gas control valve thermostat is suspect.
I believe Rheem 41VRP50N has Honeywell or White Rodgers electronic gas control valve.
Open following link to identify gas control thermostat and see typical error codes.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Honeywell
Replacement gas valve can be purchased from Rheem.
3) Combustion parts and tubes need cleaning, and bleed gas line for air and water contaminants.
4) Water heater has sediment build-up coating burner transfer surface and covering thermostat.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Year of manufacture for Rheem water heater is 2nd two digits of serial number, so XX03.. would be 2003.
Add a comment and say what you did to solve problem.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Rheem Water Heaters
Installed the timer last week, we have it to cut on at 4pm and shut off at 10pm, it will come on at the right time, and even shut off at the right time, but for the first time only, once it hits the 10pm...
Your clock motor is not correctly wired to the terminal block. Carefully review the connection diagram for the line and load leads and the timer clock leads. Somewhere in there you made a mistake when connecting the wires. If not there is a defect in the clock mechanism and you should replace it. For warranty information please refer to the instructions or the place you purchased it from for assistance.
John
Dec 14, 2010 | Intermatic WH40 - Water Heater Time Switch...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
Aug 23, 2009 | Kohler C3-200 K-4709-96 Biscuit Elongated...
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Wash heads on Brondell swash 450 will not come out
Copy and paste this into Google or any search engine!
http://www.brondell.com/dealersLocator.php
Jan 26, 2009 | NRS Brondell Swash 450 Toilet Seat -...
NRS Brondell Swash 800 Bidet - Electronic Toilet Seat - Elongated White Logo
105 people viewed this question
Top NRS Water Heaters Experts
Donni Steen
Gil Shultz
Are you a NRS Water Heater Expert? Answer questions, earn points and help others
