Motherboard Shuttle FS51 Problem losing date and time when off for a while. Believe new CMOS battery needed Are you able to advise the type/ number and voltage of suitable battery. Are you able to advise on ease of access to locate and replace battery. Many thanks
  • 644 Answers
There should be a few screws at the back of the case, undo them all and take them out, pull the case top off, if you kneel down with front faceing you pull from the back and up towards you.
Inside you will see the mother with all the cables attached to it, just to the bottom left of the processor fan and behind the pci (white) slot you will see the battery, it is round and silver, to take it out there is a liitle clip holding it in place, push the little clip backwards and the battery will come out. The battery is a 3volt lithium battery, if you take it to your local pc store they will be able to sell you one. Put it in with the writing facing you, you will notice that the bottom of the battery is slightly thiner than the top. Put the case back on the opersite way you took it off and tighten all the screws. By the way you will need a philipes screw driver in order to take the cover off. hope this is some help.
Posted on Feb 04, 2010
Testimonial: "Clear constructive information that is most reassuring and will make the replacement straightforward. Brilliant many thanks db"
  • 4,806 Answers
The CMOS battery you need is a CR2032 3V battery. You can get them from places like Radioshack, PC World or any good computer store.
Click on the link that I have provided below, it takes you through to Radioshack where you will see the battery for yourself>>>>>
http://www.radioshack.com/pwr/product-reviews/Power-Batteries/Home-office-power/Calculator-watch-batteries/RadioShack/p/2062105-CR2032-3V-230mAh-High-Energy-Lithium-Battery.html
Regards.
  • Lee Hodgson
    Lee Hodgson Feb 04, 2010
    As soon as you have seen the battery on the motherboard you'll know what to do. They are very easy to replace and just pop out of the housing.
    When you have the new battery installed all you have to do is set the time, date and year.
Cmos battery problem
If you change the Date and Time and when you next boot up your computer the Date changes to some previous date then the CMOS/BIOS battery is flat and it needs to be replaced. Most motherboard use a 3 volt coin size lithium battery type CR2032 you need to check which type od BIOS battery your motherboard uses.
Jul 16, 2012 | Intel Desktop Board D410PT with integrated...
Amilo Pi 3525 cmos battery
Most laptops require you to take the laptopapart to get to the CMOS Battery. It will be a silver battery about the of a nickel on the motherboard. The most common isCR2032. Also sometimes the battery will be in a vinyl covering and have acable that attaches to a port on the motherboard. Which ever type you haveyou'll need to either remove the battery or unplug the cable and let the laptopsit for an hour or two. Then put it back, reassemble the laptop andreboot the laptop. With the CMOS battery out the computer will lose thedate, time and password.
May 03, 2012 | Computers & Internet
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
I have an intel g41 motherboard....every time i switchon d pc...it shows check cmos error and the time and date are set to defaluts
This error occurs when the BIOS battery is flat. Replace the BIOS battery, most motherboards use a lithium battery type CR2032, this is a coin size battery. Check the BIOS battery type used on your motherboard before you purchase the battery.
After replacing the battery go to the BIOS setting and set the Date & Time etc. and you will not have this CMOS error.
Aug 10, 2011 | Intel Motherboard
Loses time and date, loses temp files, bluescreens on line alot
the time and date is down to the cmos battery change it for a new one.
the blue screens could be a number of things could be windows,ram,hard drive,power supply,cdrom drive,motherboard.
Feb 19, 2011 | ASUS A8N-SLI Premium Motherboard
I have put new CMOS but it is still not showing the correct time and date
My advise is that you need to change the battery of your motherboard. The coin-type battery. I hope it will solve your problem.
Mar 04, 2009 | ASUS Computers & Internet
Cllock does'nt time when shut down ?
Most probably your CMOS battery needs replacing.
Jan 06, 2009 | Averatec 3200 Notebook
Cmos battery dead - needs to be replaced
Sounds like you need to change the CMOS battery, the time being wrong everytime you boot is a good sign but also it losing its settings in bios is also another sign
Dec 26, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
