Question about RCA RS2656 Shelf System
RCA RS2656 Shelf System Can hear the motor spinning but will not eject or close, but I can spin the gear manually then pull it open or close with my hand. Can't see how to get to the gears and belts underneath with out doing a complete tear down. Is there and easier way?
  • 88 Answers
No easy way for this one you will require a service manual. this will give you info on how to replace the belts and part numbers
Posted on Feb 04, 2010
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Cant open cd rom
The cd door is jammed, or the timing gear is out of sync, worn gears, and a small loading belt is broken.
Apr 21, 2012 | RCA RS2656 Shelf System
Dvds will not play and system wont open
stucked up mechanism you need to open the cover and lubricate gears and sliding mechanicals after lubricating press the eject button then help the motor to spin by gently pulling tha tray then thats it repeat the eject and close command untill the system runs properly..
Apr 06, 2012 | Televison & Video
NEED OPERATION INSRUCTIONS
Type this into your search bar and ignore the top sponsored listings until you get to the website of your manufacturer.
RCA RS2656 pdf. manual
Feb 06, 2010 | RCA RS2656 Shelf System
The 5 cd changer tray will not open but the motor is still workin
i had similar problem with 1 cd inside. i turned unit upside down gave little wiggle turned rt side up and it opened.
Jul 05, 2009 | RCA RS2656 Shelf System
CD changer major problem
You probably have a small plastic gear stripped out or a belt slipping and it will need to be replaced. I wouldn't recomend a do it your self repair. This is most likely a job for a professional.
May 23, 2007 | Sony MHC-GX450 CD Shelf System
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
RCA RS2656 Shelf System Logo
152 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
