Following a replacement hard disk being fitted at factory in October, a fault developed - initially a blue error screen which said '' hardward installation error, reinstall or ..'' - then sceen flashed off and notebook performed as normal. Now the sreen is weird - part of the blue screen is visible and then below it is white with lines. I have 3 year extended warranty but having had it collected for repair, they now say not covered and will cost 322 pounds. Is this likely to result from their earlier repair? as I cannot install hardware and therefore cannot have created the error
1. Turn OFF the main power switch and turn it ON again,
and conduct the following setting. [Service Mode] ->
[System 1] -> [Initialization] -> [Data Clear].
I.11.14.8 Initialization-Clear All Data
2 Format hard disk - -
3 Replace the hard disk. - -
4 Replace MFPB
Maintenance item No. U021 Memory initializing Description Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history and mode setting. Also initializes backup RAM according to region specification selected in maintenance item U252 Setting the destination. Refer to *1 of the maintenance mode item list about the item initialized. Purpose To return the machine settings to their factory default. Method 1. Press the start key. 2. Press [EXECUTE] on the touch panel. 3. Press the start key. All data other than that for adjustments due to variations between machines is initial- ized based on the destination setting. 4. Turn the main power switch off and on. For errors occurred, turn main power switch off then on, and execute initialization. Error codes U024 HDD formatting Description Initializes the hard disk. In addition, the following settings are also initialized by initializing the hard disk. System menu (user login administration, job accounting, address book, one-touch keys and document box etc.), shortcuts and panel programs Purpose To initialize the hard disk when replacing the hard disk after shipping. Method 1. Press the start key. 2. Press [EXECUTE] on the touch panel. 3. Press the start key to initialize the hard disk. 4. Turn the main power switch off and on. Description Codes Description 01 Configuration initialization error 02 Counter initialization error 20 Engine initialization error 40 Scanner initialization error 2JZ/2JX/2JV/2H7-5 1-3-23
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system. Also this error comes when there is bed indexing unit in hard drive. You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set first boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows. Thanks for using FixYa.
Hello Sir, Hi, the blue screen is commonly caused by a bad memory module. you may need to buy replacement memory modules, ask a computer shop if they have a module for your Mini, and have them replace the it. If the problem still persist, reinstall your Operating System. thats it.
Solution A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on. 2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit. 3. Press the back arrow . The message INITIALIZE DISK displays on the control panel. 4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
NVRAM initialization Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display. 2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit 3. Press the up arrow . 4. Press Menu . The message SKIP DISK LOAD displays on the control panel. 5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Generally changing the
cylinder (blade and developer) and adjust normaly TD sensor and ID sensor, usually it is solved. If it is not thus it
proves the following thing: press point and numeral (enter) simultaneously for
more than 10 seconds until this is extinguished clarifies the service call. If
the problem persists can be the hard disk, change.
Generally
changing the cylinder (blade and developer) Initialize
td and id sensor usually it is solved. If it is not
thus it proves the following thing: press point and numeral (enter)
simultaneously for more than 10 seconds until this clear the service call. If
What was the error on the blue screen? need the error and the error number.
I would check the cable connecting the hard drive to the motherboard and replace it. also try plugging it into a different plug if its sata
