Question about Dell E207WFP LCD Monitor
Power switch is stuck on! - Dell E207WFP LCD Monitor
    Problem Solver:
  • 18 Answers
Hammer. I can not guarantee results, nor will be held liable for any damages. OK...in all seriousness, try blowing air into it. Sometimes its just dusty, and a good poof of air will clean it enough to work. Advise...dont spit.
Posted on Feb 04, 2010
Testimonial: "Sounds like a FIX!!!"
Element on light stays on, element in use light won't come on for the top burners on
One of the burner switches may have a stuck "element on" arm inside. I found mine by unplugging the switches one by one and restoring power inbetween. Once I restored power and the light went out, I knew I had the problem switch unplugged. Popped it open, freed the stuck arm. Reassembled, twisted the switch a few times to ensure smooth operation and reinstalled the switch. Problem solved.
Dec 09, 2013 | Kenmore 96422 / 96424 / 96429 Electric...
Power window stuck down ford expy 03
Window.motor or switch is bad. need to pull of the inner door panel and test for power at the motor connector when the switch is being pushed. Unplug the connector @ the motor and test for power at both wires in the connector. There should be 12v on one at a time and the opposite wire will power up when the switch is toggled to the other side. Also should be a good ground measured on the opposite terminal that doesn't power up when the switch is pushed. What the switch does is alternate the power and ground depending on which way it is pushed. If those tests are good its the motor. If not its the switch.
Aug 21, 2012 | 2003 Ford Expedition
My 99 GMC Safari has heater stuck at 75% defrost and 25% vent...no leg heat...something is stuck...how do I get at it to loosen it up or fix?
blend door actuator is stuck or burnt out or actuator door is jamed
locate and place remove motor actuator check if blend door move freely
if not repair or disloged foring object (pencil pen---comb---etc)
if ok before installing actuator plug back in harness and move selector switch
if it fails check for power if power replace actuator if no power check switch
Apr 02, 2011 | 1997 GMC Safari
Power switch will not power on the Laptop
power button switches are usually very reliable and very unlikely to fail. However, sometimes the button that presses on the switch can become stuck in the on position - if it is stuck in that position the mboard cannot boot - make sure it isn't stuck. next check the AC adapter is working and is capable of charging the main battery? Most laptops will not boot when just the AC adapter is connected, and the main battery must be capable of being charged to at least a minimal level and be charged to at least that level in order for the AC adapter to work to help boot the computer. hope this helps
Oct 26, 2010 | Gateway Computers & Internet
1800 power washer will not run - power is getting to on/off switch
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Nov 12, 2009 | Campbell Hausfeld 1800 PSI Electric...
Tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Jan 08, 2009 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Stucked power switch
Open the panel and check if its anything you can do yourself - cleaning or reassembling. not much else ;] Do a dry clean, you dont wan't any liquids around an open cellphone. Good luck
Apr 09, 2006 | Nokia 3230
Dell E207WFP LCD Monitor Logo
227 people viewed this question
Alun Cox
