Question about Toys
Secret journal will not open it just keeps asking to input code after accepting it
  • 32 Answers
Check it for a reset or take batteries out and let it sit awhile before reinstalling them. It may reset the password allowing you access. Make sure to try it with new batteries too, sometimes low batteries make toys act up. Good luck! =)
Posted on Feb 04, 2010
What if your journal keeps asking u to reenter your password
you can get a thoothpick and put it into the little hale in the front (i mean it is rally litttle and it looks like its decoration but its not) and put it in push and it will open! now you want to make a new password
Feb 02, 2013 | Mattel GirlTech Password Journal 6
Hitachi 46w 500 screen says locked
reset the tv by pressing the reset button.
Aug 21, 2008 | Televison & Video
Cannot access my email account
Reenter your password or recover your password by posting your secret question you have have entered when you have signed up in yahoo mail account.
Feb 07, 2012 | Yahoo Mail
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
I keep trying to enter my code to start my phone but the screen says that my phone is locked and will not accept any input!
send it to a service center to get it unlocked.
possibly they will ask for proof of ownership.
Jun 12, 2011 | Samsung SGH-S5230 Cell Phone
How can I disable a Parental code that has been entered into my tv by some one. The tv is a Sharp Model LC-C4067UN Sharp Aquos
Press the menu button and select 'Parental CTRL' whcih will be located somewhere on that menu or in other submenus. When selected you will be greeted with two options:
  • New Secret No.
  • Secret No. Clear
Choose the 'Secret No Clear' option to clear the parental settings for the TV.
May 04, 2011 | Televison & Video
My tv keeps asking me my input secret no.it says time over. how do i solve this problem? i cant watch any other thing on my tv. and i dont know the secret number
Feb 26,2011
my tv keeps asking me my input secret no.it says time over. how do i solve this problem? i cant watch any other thing on my tv. and i dont know the secret number .my brand of my t.v is sharp aphrody...
Dec 26, 2009 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
I dont know where to find my secret question for my xbox 360
If you go to the Hotmail website you will see 'Forgot your password?' link under where you would normally enter your password.
From here you input your e-mail address, the security code generated and the next section will give you 2 options on how to reset your password :
Use my location information and secret answer to verify my identity
or
Send password reset instructions to me in e-mail
If you know your secret question you can input in there and hopefully you can then reset your password.
If not then you'll have to e-mail Windows Live customer services regarding this situation and they'll probably ask obscure questions like :
- If you have MSN messenger contacts and if so who are they
- If you've used an Xbox 12 Month Prepaid Card what is the Serial number
- What were your recent emails, recent contacts via email etc,
- IP Address when logging in to the account or of your 360.
Apr 18, 2009 | Microsoft Xbox 360 Console
Hey thanks!
jess, if it won't accept the code. try disconnecting your ground terminal for a few minutes, then reconnect and try entering your code again
Dec 18, 2008 | 1995 Honda Accord
Unable to change v-chip code in my sharp television set HELP
Go to Sharp webste http://www.sharpusa.com/ download your manual for the tv and whala it is done...
Nov 14, 2007 | Toshiba 32A33 32" TV
Toys Logo
131 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
