Question about LG LFX25960 Bottom Freezer French Door Refrigerator
Lights in refrigerator stay on when doors are closed
  • 291 Answers
You have either a bad door switch or a bad control board. Unplug the refrigerator, remove the door switch for the refer section, unplug the wiring to it, and plug your refrigerator back in. If your lights are off, replace the switch. If the lights are still on , replace main control board that controls the lights. Good Luck, Appliance Specialists
Posted on Feb 04, 2010
    President:
  • 2,468 Answers
Take a putty knife and pry out the door switch from its resting place in the door,take some electrical cleaner and clean and lube it then try it again,if it still doesn't make/break connection,replace it,a lot of times they just get sticky from spills and dirt,etc
The light is staying on when the doors are closed
Press the door swtich inside the fridge. If you press the door switch close and the lights still don't turn off then you have a faulty door switch. They are cheap to replace.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | LG LFX25960ST Stainless Steel French Door...
LG Refrigerator; light stays on, not cooling
There is a recall for that problem the main board is bad. Contact LF for advise
Oct 14, 2009 | LG LFC25760 French Door Refrigerator
What is the light switch button for in the fridge section? why does the light stay on in the fridge with the door closed when the switch inside is on ?
The switch is curved so when you close the door the light will also close.How do you know if the light is on when the door closes?Try pushing on the switch and you will see that the light will close.If that is what you are asking.If you push on the switch and the light stays on then you have a faulty switch. hope this helped:)
May 11, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Jan 18, 2006 | Hoover HCA331FFK
LG LFX25960 Bottom Freezer French Door Refrigerator Logo
214 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
