Question about Cycling
Where can I get 2 flywheel bearings for a model 65c exercise cycle?
  • 425 Answers
From a dealer who keeps your type and model exercise bike. OR take them to a bearing specialist and they will most probably match them to an off the shelf item.
Posted on Feb 05, 2010
Ni-Trac VA-500 exercise bike ( which I bought 2nd hand, in good condition) resistance has stopped working
If it was clicking the resistance motor is stuffed replace it they are quite cheap and easy done, but also make sure the flywheel is tight as they loosen over time as well. You'll need the crank tool, I made one from a m20 metric fine thread and drilled and tapped but you could probably get one from a local cycle shop. Easy job, worth doing these bikes are real nice ??
Jan 30, 2015 | Exercise & Fitness
Do I need a pilot bearing for my flywheel? No one lists it, for the Accord
You definitely have a pilot bearing, ask a. Napa dealer to find you one, if they don't see it in the book listed.
its going to be part of the clutch kit you'll be buying to replace your old one.
in the kits you get a pressure plate, release bearing, disc, alignment tool, and pilot bearing, Beck Arnley is a good choice.
if you want just a bearing you'll probably need, the input shaft diameter where the bearing rides, the inner diameter of the flywheel hole it's inserted in, and the depth of the hole in the flywheel.
you should have to much trouble finding one.
Jun 12, 2014 | 1992 Honda Accord
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
I want to know if I can put a deutz engine in a 1998 Durango and if I can get it adapted to transmission
It wi9ll be possible to do this but you will face problems with the spigot bearing in the crankshaft for the clutch shaft and clutch mounting to the engine flywheel . The adaptor can be made by a quality engineering shop and you will be looking at engine mount modifications. Do your home work carefully as it could amount to be a costly exercise for little gain
May 10, 2014 | Cars & Trucks
Recently assembled and tried bike. There seems to be a catch/hitch in the rotation when pedal at bottom. It should be smooth. What could be wrong and how to fix?
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
Mar 22, 2014 | Kettler Giro GT Programmable Cycling...
RESISTANCE PROBLEM WITH FREEMOTION 350R
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
Mar 13, 2010 | Tunturi T30 Programmable Treadmill
Hello. We have an Excel 395 Recumbent Magnetic Bike that is making grinding noises when used. Is there any easy solution to fix it myself. Or, should I just throw it away? Thanks, Greg T.
Sorry just saw your request, you'll have take the side panels off and look for read power on the frame this is a indication that the bearings on either flywheel or pulley assembly are destroyed depending on what you paid for you may want to get rid of it if you haven't already.
Jan 07, 2010 | Stairmaster 3800RC Recumbent Exercise Bike
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
Cycling Logo
48 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
