Question about Canon Powershot SX110 IS Digital Camera 9.0MP
Canon power shot G5 wont power on but the range finder assist type light on the front flashes :( new battery new charger...any help would be apreciated. Cant find a refrence to this problem anywhere...
    Guru:
  • 513 Answers
Possibly there may be a loose screw inside the camera, floating loose. Vifration over the years can knock it loose. Likely a fuse is blown and the screw needs to come out. Contact canon about a repair.
Posted on Mar 20, 2010
I just purchase the Canon Power shot SX 130. Batteries are new and after a few days the camera batery light is flashing and I can't take any pictures the camera shot down. Please help.
Buy a proper NiMH rechargeable batteries (Sanyo Eneloop for example). Modern cameras will drain alkaline batteries in the matter of hours, not days.
Dec 30, 2010 | Canon Cameras
I have an apple mac g5 10.4 osx. the mouse has a light instead of ball and i got a warning the battery was going dead. i have bought 8 batterys and none work i bought panasonic cr2032 but no work. can you...
Thanks for contacting Fixya Support, I am glad to assist.
The issue may not be with the type of CMOS battery you are attempting to use, so much as what you are doing once you install the new CMOS battery.
You need to make sure that after you install the battery, before replacing the Air duct and closing the chassis, you press the SMU Reset button on the logic board then attempt to restart your Power Mac G5 and see if it makes a difference.
I would recommend you view the PowerMac G5 manual I have provided for you below, in order to get more a perspective on the process of replacing a battery in the PMG5.
Link:
Replacing the Battery in PowerMac G5
Let me know if this helps.
Regards,
-Mactechtrainer
Sep 14, 2010 | Apple Power Mac G5 Desktop
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
Wont take pictures with flash
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Apr 24, 2009 | Canon PowerShot A720 IS Digital Camera
Flashing indicator lights when treying to power on my a540
Hi there, I can help you with that. Do this:
Turn the camera off.
Take out the batteries for 5 minutes.
After 5 minutes, put the batteries back in (or get a fresh set).
Then turn the camera back on.
Let me know if that helps or not with a comment. If it helps, feel free to rate my answer accordingly. Thanks for coming to FixYa.
Rob
Feb 22, 2009 | Canon PowerShot A540 Digital Camera
Nintendo ds wont charge red light flashes and goes off
You can always buy a new charger for your DS, but if that doesn't work, buy new batteries. Ask your local gaming store for assistance, they can usually help you with whatever you need.
Dec 26, 2008 | Nintendo DS Lite Console
It wont turn on
Hello
First, you must be certain that your battery pack is still good.
You have to clean all connecting point (between the camera and the batterry) with a dry clean cloth inside the battery pack compartment.
Another think to check, is the date and time battery (dime size battery located inside the battery pack compartment) to remove it, slide the battery case out and change it. Since the battery is install at the factory, it verry possible that there is no more power. At the end of your owner manual, you will find, before troubleshooting section, the way to remove it, it verry easy, no force need it.
A deffective flash card can also cause the problem. Remove also the flash card and replace it by a new one or another one that you have.
When the battery is fully charge, install it along whith the new time and date battery. Leave the camera alone for a couple of hour in order to let the board get some refresment. Try to put it on, if it not work, slide in and out the battery, couple of time, close the compartment and try again.
In many cases, the camera will start and you will have to put the time and date, if the battery (time and date) was warn out. Make sure that your screen is on. You ready to go. :)
Feb 15, 2008 | Canon PowerShot G5 Digital Camera
Canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Dec 16, 2007 | Canon PowerShot G5 Digital Camera
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
