Question about Maytag MDE308DAYW Electric Dryer
What do i take apart the dryer to replace the heating element in my mde308dayw maytag dryer? the back seems to be attached to the sides and unable to remove. thanks
    Genius:
  • 1,122 Answers
The steam on the front was 2 spring clips,one on each side in the front, use a putty knife to pop it up,then looks on the back wall and you will see the thermal fuse and the heater coil-mike
Posted on Feb 05, 2010
How to replace dryer heating element?
Use a putty knife to pop the top. Then get the front off. The element is held in place by 2 screws unplug 2 wire and pull out the element.
My video from my el cheapo LG phone:
Oct 03, 2012 | Maytag MDE308DAYW Electric Dryer
Access ing the heating element
Unplug the machine and take it outside. Inspect the venti for lint buildup. Using a putty knife release the top spring clips then remove the screws that hold the front panel on. You cannot and do not work from the back side of the machine. Like this:
Aug 22, 2012 | Maytag MDE308DAYW Electric Dryer
How do i get dryer apart to get to heating element model mde308 dayw
unplug dryer, move out from wall so you can get to the back. use a 1/4" nut driver and remove the rear panel. The heater element is on the bottom right. before replacing check for continuity. if the heater has continuity, check all of the other componets on the rear of the dryer. i would advise to check the small white thing with 2 wires connected.
Apr 29, 2012 | Maytag Dishwashers
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Trying to replace heating element
its located inside the heater duct assembly on the rear side of the dryer,you need to unplug the unit,remove the rear cover,then remove screw holding the duct after marking and removing any wires attached to the duct and heating element,unscrew the element from the duct assy and reverse procedure to reinstall
Jan 16, 2010 | Maytag MDE308DAYW Electric Dryer
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
How do you expose the heat element
Take of back of unit, unplug first. Heat element is near heat duct side with wires attached to it. Unscrew and slide it out. You could also put a tester to each wire to see if you have a complete connection. If ok check thermal switches, one could have gone bad.
Aug 17, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag MDE308DAYW Electric Dryer Logo
333 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
