Question about HP 48gx Calculator
My HP48Gx has a problem with the last keyboard column(F L R X arrow / * - +). It stops working and if you shake it then it will work again. Any ideas?
  • pablorva
    pablorva Feb 26, 2013
    I have exactly the same problem. Did you find a solution?
  • pablorva
    I have exactly the same problem, did you found a solution?
  • HP Master
  • 8,016 Answers
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Posted on Jun 16, 2010
Hp48gx was dropped, now difficult to turn on if at
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
May 10, 2010 | HP 48gx Calculator
Tip
How to find no. of rows and columns in Worksheet.
Hello everybody, this would be my first tip on FixYa.com. Number of people might not be aware how many rows and columns are there in Microsoft Worksheet.
This is how you can find out.
1. Select A1 cell in the worksheet
2. Now press Ctrl + down arrow from your keyboard, that will take you to the bottom of the row. You can find the number on the left side.
3. Again select A1 cell in the worksheet and press Ctrl + left arrow from your keyboard, that will take you to the last column of the worksheet. Now to number, just type "=column() " , without quotations, that will give you the number of the column.
Microsoft Worksheet columns is number from A to Z, again from AA to AZ, again from BA to BZ and so on till it reached IV in Excell 2003 and earlier version.
Microsoft Excel 2003 and old version has 16,777,216 cells per worksheet (65,536 rows * 256 columns).
Excel 2007 has 17,179,869,184 cells per worksheet (1,048,576 rows * 16,384 columns).
on Jul 27, 2010 | Microsoft Excel for PC
The calcutor doesn't turn on from the first time. It takes too long to turn on and at random. Also the soft keyd don't work. I try to set the modes but when I press shoose nothing happens.
The following testing procedure valid for the HP 48G should work for the HP48GX. If any the tests fails the calculator requires service.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Sep 23, 2009 | HP 48gx Calculator
Have a 48GX that stopped working, placed new doubleA batt no response... Note a wird meshed blue line at the center of the screen... Thx jsd
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 15, 2009 | HP 48gx Calculator
Hp48gx is autistic
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 16, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
I HAVE A HP-48GX THAT WANT TURN ON.
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Feb 05, 2009 | HP 48gx Calculator
Download music
I hate to tell you this, but it sounds like you downloaded a very bad virus as well.
First, boot the computer while holding down the F8 key. Continue holding this key until the screen changes. Use the arrow up key to boot in 'last good configuration that worked. Immediately open control panel, then click on performance and maintenance, then in the left column 'system restore'. Choose 'restore my computer to an earlier time' and pick a date before this happened.
If it is successfully restored immediately download a good anti-virus, update it and run it ASAP. I strongly suggest AVGfree 8.0 from filehippo.com. Until you do this the virus is still in your computer and eventually will cause further problems. Good Luck!
Dec 03, 2008 | Gateway 2520915 Keyboard
My HP 48GX with COGO Card is running slow.
You should perform the dagnostic tests.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 12, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
218 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
