Question about Sony KDF-42WE655 Television
How do you remove front lower panel to access lampligth
  • 10,594 Answers
There are two thumb screws at rear on lower corners in Sony KFD-42WE655, lose them and pull out lower front panel to get access to lamp.
Lamp replcement procedure is written in user manual, check page-17 for details and click Sony Support if you want to download manual copy.
If model of your tv is different, let me know.
Hope this info will help you.
Thanks.
Posted on Feb 12, 2010
How do I access the drain pump on a Whirlpool Duet washing machine model WFW94HEXW2?
Hi Marc,
Unfortunately, access to the pump & filter is harder on the HEXW2 model than the Duets with the removable lower panel.
First you have to remove the lid panel (screws in top rear), then pull slightly rearward and up/out.
Next you'll have to remove the control panel, then remove the front drum boot from the front panel lip. A large diameter thin wire spring holds it in place, located just under the rubber lip edge. Begin the spring removal from a wire tab located toward the lower portion of the lip.
Then remove the door latch screws (IIRC), and the screws at the bottom edge and top of the front panel. The entire front panel must be removed to access the drain filter.
Nov 03, 2014 | Whirlpool Washing Machines
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Remove front lower panel to access filter
there are 3 screws that hold on the lower panel, they can be removed with a 7mm socket or a phillips screwdriver, after removed the panel should slide down
Sep 07, 2010 | GE WBVH6240F Front Load Washer
The door won't open
Whirlpool Front Loading washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Aug 23, 2010 | Whirlpool Washing Machines
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i access the water pump on the frigidaire affinity atf6000
There should be to screws at the bottom on each end of the lower front panel. Remove them and the panel will fall down off its upper locating pins and you can then remove the panel. The water pump should be right at the front on the lower right corner. Make sure you unplug the machine first if you are going to be working in there.
Jan 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Removal of front lower panel
My similar machine has two screws on the bottom. Remove and out it comes.
Dec 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Sony KDF-42WE655 Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
