Question about Emerson MW8107WA Microwave Oven
Sometimes, only sometimes, mhen we run the
Sometimes, only sometimes, when we run the microwave, it trips the breaker. It totally bypasses the outlet breaker. It can go along fine for days then "pop".
It's a model MW8107WA
  • 72 Answers
Your microwave is ok, your breaker is bad or is not strong enough for the microwave. microwaves need a dedicated 20amp breaker
Posted on Feb 05, 2010
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Tripped a breaker
sometime the kitchen has gfc outlets around the walls and one of them tripped. but not likely , it sounds like the microwave fried some valuable circuitry.
May 12, 2008 | Goldstar MV-1501 Microwave Oven
Emerson MW8107WA Microwave Oven Logo
117 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
