Question about Car Audio & Video
Hi just tried fitting my ripspeed dvd player power comes on for about 10 secs then says bye bye and goes off can any one help??????
Check the fuse on the red wire hasn't come loose.
Check the fuse on the yellow wire isn't blown.
Check both are connected simulataneously.
Common fault!
Posted on May 28, 2010
  • 3,204 Answers
Have you connected the ignition wire as it will do this if the memory wire is only connected. check the fuse is in the fuse holder and its good.
Posted on Mar 26, 2014
I've pushed my button in that ejects the screen on my dv720 ripspeed any solutions to get my screen out???
Posted on Jan 30, 2012
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
I need a ripspeed dvd 733b manual
You may download a copy of the manual here.
Dec 15, 2012 | Televison & Video
Hi i have a ripspeed dv710 plays the radio fine put a cd in and theres no sound but timer goes up si a no its plying same on dvds you can watch the film but no sound anybody help??
it sounds like it was installed incorrectly. there must be amps in the car. when the dvd player was installed they hook up a blue wire on the back of the radio. its a power antenna wire . switch it for the blue white wire and youll be in buisness
Feb 04, 2010 | Car Audio & Video
I need help wiring a sub to a ripspeed dvd-730 cd player.because it has to aux-in wires but 1 sub out wire.
the phono out is the feed to the sub, if your amp has high input socket then run feed from normal speaker feed from head unit, or pop into halfords and ask the ripspeed specialist
Dec 22, 2009 | Car Audio & Video
Instruction manual and installation manual for ripspeed dv725
fitted the dvd player but no sound could u help
Jun 07, 2009 | Car Audio & Video
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
Feb 12, 2009 | Kenwood DV-605 Multi-disc DVD Player
Ripspeed dv-725 problem when trying to play dvd it says attention, do not use this function!
Your Player doesn't support DVD/CDs that are burnt on High Speed DVD/CD Recorders. To resolve this, you should either burn DVD/CDs at 4x(DVD) & 24x(CD) or go for a newer, higher end DVD Player.
Jun 25, 2008 | Televison & Video
I have a ripspeed dv920i in car dvd player but it has just turned off and wont come on again i carnt find any one to repair
I had the same problem, HALFORDS sent the unit away to have the firmware re-flashed and now it works perfectly again..... These units were re-called apparently due to problems with the software.
HALFORDS staff may be able to advise you about where the unit can be repaired.
Jun 20, 2008 | Car Audio & Video
Car Audio & Video Logo
795 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
