Question about Amana Dryers
My dryer stops mid cycle. It starts right up again after push start. The timer was changed...same thing happens
4 Suggested Answers
  • 1122 Answers
SOURCE: Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Posted on Oct 02, 2008
SOURCE: Whirlpool Dryer LER7646EQO - Won't Start
my whirlpool electric dryer not turning,there anyone can help
Posted on Mar 27, 2009
smartr10U
  • 1305 Answers
SOURCE: My Magic Chef Dryer stopped working mid cycle last
Check the circuit breakers for the dryer first. Remember when you reset the breaker, to turn it all the way to the OFF position firmly and then back on.
Posted on Jun 08, 2009
Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Nov 04, 2009 | Kenmore Dryers
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
81 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
