Question about Cell Phones
Car kit my wifes phone now displays -Car Kit- and cannot receive incoming calls. Please help me solve this problem. Thanks! We've had the phone for over 2 years - i have the same model but mine is working fine. It is an LG phone from sprint - i am unsure of the model number atm. Thanks!
    President:
  • 1,017 Answers
The model/serial number/IMEI number, should be written under the battery.
If you switch off the Bluetooth car kit, when you take the handset with you, it might solve your problem.
Posted on Feb 20, 2008
My phone has no sound, and it now says "-Car Kit-" WHY?
Firstly i come to your 2nd question where you asked what the meaning of Car Kit. Bro Car Kit means a sound system which contain also blue tooth, DVD, FM etc. So in Car Kit any one can pair their blue tooth devices i mean your cell phone where blue tooth are available. So when you pair your device at the define range then Car Kit will be connected with your phone so when your receive or dial a call then the Car kit speaker will be active automatically. You can hear voice from there.
Now come to your next question,
If your Car is off or you are so far from car then your speaker will be enable normally but if it don't work then means your speaker disable or inactive. As a result, you have to change your speaker by a expert technician then you will release from this problem. Thanks a lot
Nov 09, 2012 | Cell Phones
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
Nokia 3109c with Bury car kit. Phone and car kit
Lawson,
did you solve the problem?
I have a similar problem, I can hardly hear my Nokia 3109C at full volume in the Bury carkit. The workshop told me that their Nokia worked fine, they suggested installing new firmware on my phone, however I have the latest version installed (7.21).
Hans
Jul 31, 2009 | Cell Phones
ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Feb 10, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Car kit mode
it could be a liquid damage if not u need to refurbish the phone by downloading the operating system
Feb 29, 2008 | LG VX8300 Cellular Phone
Car kit setting removal
"car kit" usually means the phone got wet...
unfortunately there is no way to fix it...
Jan 31, 2008 | LG VX9800 Cellular Phone
LG TU550 phone handsfree volume
VERY poor reception and battery goes flat in about 10 hours as looking for a signal. My wifes Nokia lasts a LOT longer and has much better reception
Dec 05, 2007 | LG CU500 Cellular Phone
Says Car Kit on phone but has never had a car kit hooked up to it
A clarification on solution #1: Try pressing the tip of the knife (I used the end of a nail file) onto the lower right hand side of the charger area. That's what got it for me. If that doesn't work, try other parts of the end...
Aug 16, 2007 | LG VX5300 Cellular Phone
Cell Phones Logo
132 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
